Official A4 to M6 (T-56) Thread!
#442
Ok just received my NEW GM part #15027983 which is the clutch pedal assembly. This came as the pedal only. No hydraulic master cylinder or lines attached. Is this correct? I was under the impression that this should be the whole hydraulic system complete to the quick connect fitting.
If the master cylinder and lines are a separate part, does someone have a part# available?
Thanks
Thanks
#444
Thanks
Thanks
- Clutch Pedal Assembly #15027983 $66.00
- Clutch Pedal Bracket #15713209 $4.82
- Clutch Switch #15027967 $30.89
I found two of the following for the trucks, I think the first one is the one you need...???
- Clutch Master Cylinder/Hydraulic Line #2423561 $108.26
- Clutch Master Cylinder/Hydraulic Line #15727261 $153.60
And to finish it off, a nice new trim piece for the Steering Colum with out the hole for the Gear Selctor...
- Steering Column Trim/Cover #26072994 $0.00 / $25.77
#445
Got the pedal assm, got the trim piece and got the clutch switch.....just missing the hyd stuff.
As for the pedal bracket, although I haven't gone under the dash to test fit the pieces, at first glance it doesn't seem to be the right part. Will comment more later.
Will research the hyd line part #'s.
Thanks all for the help.
#446
#449
when you buy the clutch master...it comes with switch. you wasted $30. also, do yourself a favor, if you dont already have a new slave cylinder, buy the one for the Z06. i learned the hard way, used a used pre 99 f-body slave, it failed in three weeks. i slid the Z06 unit in, and the truck shifts really really nice. when you first bleed a brand new slave, bleed the system untill you get a good flow of fresh fluid coming out of the bleeder. then, without opening the bleeder, pump the pedal over and over and over again, this is the only way you will ever get a good pedal. when you just bleed it, the fluid goes right through the slave withough first filling it up....and it takes a ton of fluid to fill it up.
#450
this is the number for the clutch master i used personally.
Clutch Pedal..............15027983.......57.45
Brake Pedal Pad..........15706041........3.65
X-member.................15748078......127.95
Z06 Clutch/flywheel....12570806......475.86
Roller Pilot Bearing.......14061685......16.03
Clutch Master/Line......15033984.....129.02
