Official A4 to M6 (T-56) Thread!
Old Apr 22, 2007 | 07:37 PM
  #271
rao's Avatar
rao
Originally Posted by nightrunner
the t56 will not work on a 4x4 without some custom work, other than is already specified
I went back and read the whole thread - I apologize since it was mentioned earlier on.
I need to find some solid info on swapping the NV4500 into a Hummer; I am going to call some of the transmission sh ops and see what I can find out.
Thanks for the info.
Old Apr 22, 2007 | 07:45 PM
  #272
nightrunner's Avatar
Mr. Obvious
what i meant by that was that it will require a custom transfer case and have a output shaft put on the t56 for it.
and that just a 2wd t56 requires some customization to fit and a 4x4 application would take even more to work, IF it would
Old Apr 22, 2007 | 07:49 PM
  #273
rao's Avatar
rao
I understand - the T56 is out of the picture. The Hummer has a 408 with the Magnuson supercharger; at that weight and with that power I don't think the T-56 is a good idea, even if it could be made to physically fit.
The 4l65-E keeps dropping output shafts and other miscellaneous parts - 3 transmissions and counting. A swap to a 4L80-E would make more sense but the guy wants to do a manual if possible.
Old Apr 22, 2007 | 07:57 PM
  #274
Mr. Obvious
you'd need one hell of a clutch for a h2 with a blown 408
an 80e would be best, you might look at the ZF 6speed manual in the HD gm trucks like with the dmax and 8.1L or the NV4500 like you mentioned
Old Apr 22, 2007 | 09:54 PM
  #275
nice_n_lo_silverado's Avatar
I don't think a M112 could feed a 408?
Old Apr 22, 2007 | 10:02 PM
  #276
Mr. Obvious
whitt1 had one on a 402, i think he got about 5, maybe 6psi with a 2.75" pulley LOL
he was going to go with a 3.3L whipple but dont know if he did or if he still has the mp112
Old May 2, 2007 | 02:19 PM
  #277
Tootall's Avatar
here's a thread about making your own clutch line out of AN fittings
https://ls1tech.com/forums/showthrea...clutch+connect
Old May 6, 2007 | 09:19 PM
  #278
kelleyperformance's Avatar
im doin the swap this week, thanks to you guys i didnt have the ***** to do it until i realized how straight forward it really is. im using an SSR clutch, flywheel, slave, and M10 SSR tranny. everything is supposed to come in monday, so i hope to get it done by saturday. anybody have a time frame on this? also any tips, tricks, or anything i may need to look out for? thanks
some SSR tranny stats:
http://www.autoblog.com/2006/12/08/a...andr-part-iii/
Old May 6, 2007 | 10:15 PM
  #279
TurboGibbs's Avatar
Good deal. It is long but pretty much everything is covered in this thread.
Old May 6, 2007 | 10:33 PM
  #280
ok great, thanks. ive already read thru this incredablly long thread, so its all in the noggin
