Non-lockup converter
Is it and aftermarket converter since 700r4 converters were lockup also.
But without lockup and with any higher stall there will be alot of excess heat build up from the slip of the converter. The engine rpm in 4th will ussually be way under most reasonable stall speeds. and being under the rated stall will generate heat. Any engine motion not turn directly into vehicle motion be come heat.
How did he end up with a 700r4 converter without lockup and how does he know the converter does not have lockup?
I mean people do make them that way (never understood the concept) but they do.
Well running a non lockup hes gonna need alotta cooler. There is also a valve that can be placed in the lockup bore to increase lube and cooling. I have seen them but never actually used one because to me and OVERDRIVE trans without lockup is a waste of time . May as well be a 3 speed.
