No 3rd gear...
Old Jul 24, 2006 | 09:42 PM
spinz71's Avatar
Default No 3rd gear...
Got a Yank 2600 and a Transgo kit installed last week. Truck WAS running great. Today on the way home from work, I slow down for traffic and when I accelerated the truck wouldn't go into 3rd gear. When it started, the shift from 1-2 was fine. Then it seemed like it tried to "slip" into 3rd. RPMs went up and nothing happened. I let off the pedal and eased back into it but it wouldn't go into third. Got on the shoulder and shifted into "1" and eased back into it. Shift into "2" and the tranny shifts into 2nd. Shift into "3" and nothing. RPMs go up but no shift. It hung in 2nd. Reverse works fine. Fluid level & smell is OK and no codes.
Any ideas?
Old Jul 24, 2006 | 09:45 PM
RoninsDenali's Avatar
Any overdrive?
If overdrive works, then the 3-4 clutchpack is still good. If not, that would atleast be a starting point. (3-4 clutch that is)
Old Jul 25, 2006 | 01:17 AM
3-4 clutch pack is whats notorious for failing in our transmissions. it will just leave you. im sure your STS is cause for this. time for a built unit
Old Jul 25, 2006 | 01:25 AM
James B.'s Avatar
All it has to do is burn once and that will cause the clutches and plates to warp from the heat. When they distort it makes a bunch of high and low spots. The high spots heat up even more. Sorry man, it's probably done.
Old Jul 25, 2006 | 05:32 AM
spinz71's Avatar
I don't know about OD....it won't shift past 2nd. I was wondering if the stall could be causing it or if something came loose from the Transgo install. Yep, I wanted a built trans....just not the week after the cam/TC install.
Old Jul 25, 2006 | 08:04 AM
if it wont shift past 2nd then its your textbook clutch pack. sucks when you things happen the only time you odnt want them to
Old Jul 26, 2006 | 01:12 PM
spinz71's Avatar
Well...the verdict is in!!! And the winner with the closest answer is S2BS with the 3-4 clutch packs! They were toast and the 2nd accumulator piston was cracked. That was the reason it wouldn't shift into third.
So Dave at Rock On is re-building it to a Level 4 for it as we speak!
Wonder how long it will be before the G80 craters?!?!?!
Old Jul 27, 2006 | 12:52 AM
for me of course (patting self on the back) i have seen G80's crap out after a long time or real quick, kinda like the 60. real variable, some last a long time and withstand mods and stuff and some just crack
Texas5.3_1251
Mar 5, 2016 08:10 PM
97_ek
Sep 23, 2015 09:16 PM
fortune46x
Sep 16, 2015 08:18 AM
Velocity1
Sep 15, 2015 11:29 PM
