need to wiegh front end, HOW?
Old Dec 16, 2007 | 11:05 AM
TURBHOE's Avatar
Default need to wiegh front end, HOW?
i need to wiegh my front end for a coil over conversion i want to do. what is the best wiegh to do this. i know take it to a truck scale and pull front end up on the scale. however, i'm not sure how far forward to pull up. should i just pull up to about the front doors or alittle further maybe kess? i did find out that gm says that the hoe has a 52/48 wieght distribution. this should be better after the AWD is gone and coil overs up front. might get close to 50/50.
Old Dec 16, 2007 | 12:15 PM
oneslammedgmc's Avatar
I've never personally done this before, but you could find someone in your area that tunes suspension for drag cars and such and has the scales for each individual weight.
Old Dec 16, 2007 | 12:25 PM
adam1803's Avatar
The only accurate way to do it would be with individual scales at each wheel. I would weigh all 4 corners to be completely accurate. Also make sure you throw some weight in the seat to simulate driver weight and i would do it with a full tank of fuel too.
Old Dec 16, 2007 | 12:42 PM
TURBHOE's Avatar
the guy at qa1 said just pull the front of the truck on the scale. i guess i'll call him back and ask him. i don't know anybody with race car scales.
any body here that lives in maryland have scales?
Old Dec 16, 2007 | 02:15 PM
viciousknid's Avatar
Where's the Beef?
i'd pull it on the scales 50/50. it's going to have even weight distribution until your accelerating. Don't the tags on the door frames say the GVW front and rear anyway tho?
Old Dec 16, 2007 | 05:38 PM
TURBHOE's Avatar
never looked but i can.
Old Dec 16, 2007 | 11:00 PM
IMD's Avatar
IMD
Banned
you need the stiffest springs they have. 650'si believe is what i used for the same application as what you're doing.
Old Dec 17, 2007 | 05:03 AM
TURBHOE's Avatar
so how does your ride compared to the torsion bars? was it worth the swap?
Old Dec 18, 2007 | 01:54 PM
wtftalon's Avatar
corner scales is the best way to do this
Old Dec 18, 2007 | 02:29 PM
thunder550's Avatar
High on diesel fumes
It won't make any difference how far onto the scales you pull, as long as the rear tires are not on the scale. The front tires support their portion of the weight regardless of how the truck is positioned.
JordanH
Feb 28, 2017 07:22 PM
Corvette454l88
Sep 1, 2016 01:24 AM
5.3Caprice
Nov 7, 2015 08:56 PM
vmaxpro
Aug 10, 2015 07:25 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
