transmission help please.
Okay I've installed a pi converter and tci flex plate and an 4l65e.
when I turned on the truck to check the oil level I hear a loud rattling sound coming out of the transmission. LIke a coke can is inside the torque and transmission getting tossed around. What the hell is it?
Are you sure you got all of the converter bolts tightened down? Also, did you put a quart of fluid in the converter before you seated it? Was it seated completely so that the converter and flexplate could spin freely from each other before you bolted them together?
1 quart should have been enough in the converter. You sure nothing is touching the flexplate when it spins? Is the starter seated and operating correctly? Also - was the TCI flexplate dished like your stock one? If not - did you install a spacer between it and the crank?
i'll double check everthing.
