Need help: Horrible ride on my 03 Sierra. :-(
Old May 26, 2012 | 10:01 PM
MarineBlue03GMC's Avatar
Tech Fanatic
Barley do you think that the aftermarket springs are the issue or is it ultimately the fact that I'm doing a 3 inch drop?
I've definitely considered putting on the factory springs but I think I would prefer a 4 inch drop for the rear still, especially since I know a 2 inch drop would leave the rear end quite high when compared to the front end. If I used the factory springs I could use hangers and shackles to get a 4 inch rear drop right? Still I'm wondering if this would just create the same problem again since I'm going to a 4 inch drop again.
Old May 27, 2012 | 12:24 AM
barley's Avatar
let me start by saying I am no suspension pro by any means i'm just offering you my $0.02 although i am on my second truck with a 2/4 drop. To answer your question i do think some of your problem is with your springs nothing seems to ride as sommth as a factory spring. You can achieve a 4 inch drop with factory springs using 2 inch hangers and 2 inch shackles. The only thing is in your case and mine (I got Cal Tracs too! not installed yet ) we will have to get hangers directly from calvert racing or mod a set to work. I think you shouls still get the c notch too.
Old May 27, 2012 | 01:33 AM
Tech Fanatic
Hmm I actually have Belltech hangers on my truck now. So these won't work on the factory springs with the Caltracs?
Old May 27, 2012 | 02:18 AM
barley's Avatar
I think you have your parts confused shackles are on the back of the sprinh hangers are up front
Old May 27, 2012 | 03:50 AM
Tech Fanatic
Oops yeah I always get the two confused. Ok guess I'll be ordering a set of hangers from Calvert. Thanks for the help all! Maybe I'll try the factory springs and 2" hanger/shackles without a C Notch to see if that fixes the bouncing issue. Of course if that doesn't work then I'll do the C notch.
Old May 27, 2012 | 11:04 PM
barley's Avatar
https://www.performancetrucks.net/fo...-parts-499501/ Here ya go you could probably use these too
Old May 27, 2012 | 11:08 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Don't even bother, unless you're planning to raise the truck back up, you'll need the notch.
Old May 28, 2012 | 11:58 AM
Tech Fanatic
Really? I thought you could get a rear 4" drop on stock leafs if you use hangers and shackles?
Old May 28, 2012 | 12:17 PM
You can, but no matter how you cut it, a 4" drop is a 4" drop. Your problem is that the axle is too close to the frame now, and you're bottoming out. Also, your shock angles are bad.
It doesn't matter which parts you use to get the 4" drop, either setup will give you the same problem. Get a notch, and shock extenders, and you're all set.
Old May 28, 2012 | 04:49 PM
Tech Fanatic
Ok that makes sense. So do you think my Edelbrock IAS shocks will work ok with the extenders and C notch? The shocks are for a lowered truck so I want to be sure they work.
