Need help: Horrible ride on my 03 Sierra. :-(
Old May 28, 2012 | 10:07 PM
  #21
12sec.5.3's Avatar
Originally Posted by MarineBlue03GMC
Ok guess I'll be ordering a set of hangers from Calvert.
Hmmm..., I have some if you want to make a deal.?
Old May 28, 2012 | 11:48 PM
  #22
AKlowriderZ71's Avatar
11 Second Hall Moniter
Ok that makes sense. So do you think my Edelbrock IAS shocks will work ok with the extenders and C notch? The shocks are for a lowered truck so I want to be sure they work.
I'd guess that they will work just fine. Don't try new shocks until you install the shock extenders and notch. I think you'll be happy.
Old May 29, 2012 | 12:53 AM
  #23
MarineBlue03GMC's Avatar
Tech Fanatic
Ok sounds good. I'll try the c notch, and extenders, as well as my current shock, and leaf spring setup.
Old May 29, 2012 | 01:49 AM
  #24
oakley6575's Avatar
Do the extenders just allow you to use stock shocks instead of the crappy belltech shocks?
Old May 29, 2012 | 02:00 AM
  #25
No, they move the mount away from the axle a couple of inches, and that puts the shock closer to a proper working angle. I'll see if I can find a pic.
Old May 29, 2012 | 02:05 AM
  #26
oakley6575's Avatar
Aww I see. So you still use the shocks from the lowering kit. Thanks for the info
OP, when do you plan on doing the upgrades?
Old May 29, 2012 | 05:39 PM
  #27
Tech Fanatic
I plan to do the install within the next month. I'll be ordering the extenders today. Just gotta decide which brand I want to go with. Also a part of me was thinking about using the factory shocks, instead of the shortened Edelbrock IAS shocks I have, but I'm not sure if that would be a good idea. The factory shocks had a decent ride and are hardly used (They're those blue shocks that came with the upgraded suspension.) I was thinking this because my friend was saying that the factory shocks with the extenders would be a better ride than the Edelbrock shortened shocks, basically due to the limited travel of the shortened shock. Ultimately I still want to make sure the truck handles well and gets decent traction.
Old May 29, 2012 | 08:11 PM
  #28
barley's Avatar
I had edelbrocks on my last truck and really liked them but I also had the extenders too.
Old May 29, 2012 | 08:20 PM
  #29
Tech Fanatic
Good to know Barley. So were the Edelbrock shocks the ones for a lowered truck? I'd rather not have to replace the shocks if they'll work with the extendors/extensions (I'm planning to get the Belltech ones: 2003 GMC Sierra Belltech Shock Extenders - Belltech Shock & Strut Extension Brackets)
  #30
barley's Avatar
I do if MarineBlue03GMC doesn't want them
