need help from 4/6 drop guys.....
Okay I finally got a set of 17" eccalade wheels and I put them on and the tire is too big... 265/70/17...which would be okay if I did not have the 4/6 drop. I know there are some guys running this drop with these wheels
could you chime in and help a brother out!!!
What tire size are you running and do they rub.....?
I ran stockers on mine and they didn't rub. I am fairly certain tire size was a 255/70/16, pretty sure it was right around 30" tall. If like said, and your tires are 31.6" tall, then more than likely dropping to around a 29-30" tall tire should do the trick if you still want to tuck some tire
With it being a set of stockers, the offset should be fine. Factory wheels usually have a high offset and tuck a lot. I would just about guarantee he is hitting the top of the fender, not the fender lip.
i've got the same problem when i go 4/6 in a couple weeks, except im rubbing the lip and im not sure how to go around it since you can't roll plastic (stepside) and it doesn't look like i can cut much because of the bedside supports...
they are the stock 17" chrome stockers off of a friends 05 escalade. and it seems to rub when I turn. It also rubs if I hit a bump. I was thinking 275/55 or 255/60 or even a 265/65 but I am no good at this......My 275/40/20's ride great.....also I need to put in the spring spacer on the driver side to help level it out!
Here's from my experience:
I ran stock 31.6" tires and I couldn't move more than a 1/4 turn of my wheel. I couldn't even back out of my driveway, because the 1" lip caused the suspension to cycle and rub.
I currently run a 29" tire(255/55/18). I would recommend something between a 29-30" tire. You could always go smaller but I wouldn't go bigger than that.
