Need a flywheel asap!
Old Jan 30, 2014 | 05:08 PM
jonnywhoop52's Avatar
Registered User
Default Need a flywheel asap!
Hey guys I'm in need of a flywheel for a 99 GMC Sierra 1500 4.8L with a MANUAL transmission. I have called every parts place from Lima, OH to Ft. Wayne, IN. I was wondering if anyone had one for sale, need by tomorrow. Any help would be great
Old Jan 30, 2014 | 05:23 PM
Car-part.com it's a junkyard directory.
Old Jan 31, 2014 | 08:34 AM
robm-951's Avatar
sachs NFW1050
amazon has them as well as oreilly. just search each of those for that part number.
Old Jan 31, 2014 | 08:40 PM
Registered User
I bought one and it doesn't work. It bolts right up and fits but it's too thin compared to the original so I'm back to square one, but I have heard that there are spacers and longer bolts available I'm just not sure where to find those.
Old Jan 31, 2014 | 09:12 PM
Registered User
With the NFW1050 it's around 1/4" thinner than the original 4.8 Liter. So to compensate for this I've read that a spacer will push it out to take up that space, only thing with that is then I'm not sure if the original flywheel bolts will work, and where can I find the spacer part # as well as flywheel bolt #'s
Old Jan 31, 2014 | 09:29 PM
robm-951's Avatar
IDK, that's what I used when I swapped the 5.3 into my truck without any issues. Of course I didn't have a factory one to compare.
Old Jan 31, 2014 | 09:41 PM
Registered User
the 4.8 and 5.3 I thought would be close enough but I guess they aren't, haha, oh well lessons learned, it's a stock 4.8 to the NV3500 I believe and the dealership was unsure if they could get one.
Old Feb 4, 2014 | 02:03 PM
Registered User
Just for clarification, the NFW1050 Flywheel does NOT fit to the 4.8 to the NV3500 on a 99 GMC sierra. The ring gear sits an inch too far away from the starter. If you plan to do this you need the spacer and longer flywheel bolts. The problem with the flywheel is that GM and aftermarket companies have not made the flywheel for awhile. Thanks for all the help
Pimpinpete
43
Dec 22, 2017 08:13 AM
GM1697
Sep 28, 2015 08:28 PM
97_ek
Sep 23, 2015 09:16 PM
MOBBN
Sep 22, 2015 08:07 PM
