My 4L80e Build Thread
Old May 18, 2017 | 11:24 AM
  #81
tgui's Avatar
You'll want to remove that reverse checkball. I didnt on my dual feed 4l80e and reverse was slooooow to engage. All good after I removed it! I think I removed 9 & 10 in total.
Old May 18, 2017 | 11:30 AM
  #82
oakley6575's Avatar
Yes I will be removing the rev, and 2nd accumulator checkball for sure. I'm contemplating removing the direct checkball as well for the 2-3 shift.. I have all the holes in the spacer plate drilled to .125" but I'm thinking I should pull the direct checkball and call it a day...
Old May 19, 2017 | 06:59 AM
  #83
oakley6575's Avatar
I ended up finding the two cushion plates go with the ID facing down so I tore the trans back apart and fixed it. Not sure what would have happened with them installed upside down but it's right now.
I got the pump aligned and intalled, so the only thing left is the valvebody. I have it most of the way torn apart but I can't figure out how to disassemble two parts in it. I'll get it rebuilt tonight and hopefully installed.
Old May 20, 2017 | 01:56 PM
  #84
oakley6575's Avatar
Assembelled valvebody.
And that's a wrap... now let's hope it shifts out of park!
Old May 20, 2017 | 11:33 PM
  #85
Atomic's Avatar
I have a gauge for that
Is that a factory drain plug on the side?
Old May 21, 2017 | 04:10 PM
  #86
oakley6575's Avatar
Yes.. the one I have in my truck is an early core like the one pictured but it doesn't have a drain plug. Definitely a plus
Old May 21, 2017 | 08:49 PM
  #87
GMCtrk's Avatar
That's an interesting pan. All the ones I had seen were angled towards the back. Mine had a factory plug but it was recessed and not off the side like that.
Old May 22, 2017 | 08:31 AM
  #88
oakley6575's Avatar
Well, first trip to the ER last night. Old transmission fell off the jack and the yoke went through my hand. Luckily nothing broke.. Just a crushed hand and a good cut. Hand is stupid sore today. So I guess i'm out of commission for a bit.. Converter will be here thursday and im out of town thursday thru monday. Hopefully I can get back on it next week...?
Old May 22, 2017 | 08:46 AM
  #89
Sevex's Avatar
Snail Fab
Scary when that stuff happens! Sucks about your hand. I had one come off and got lucky that it went opposite of my body. Best of luck with the hand!
Old May 22, 2017 | 03:19 PM
  #90
oakley6575's Avatar
Thanks man!
