My 4l65e - T56 Swap - Could use some incite
Old Jan 24, 2014 | 01:55 PM
  #31
PaulyC's Avatar
seeing as how i havent done my swap yet i cant tell you from experience but what i have seen on a lot of other forums is that most people bolt the bell housing to the block and then install the trans. dunno if that might be something you want to try. also did you buy the trans from rpm with no core? how much did that effect the price?
Old Jan 24, 2014 | 04:29 PM
  #32
kren7604's Avatar
I've always don'e mine with bellhousing bolted to the trans...
Old Jan 24, 2014 | 05:34 PM
  #33
bgray's Avatar
TOTM: June 2007
Once I go get it in I'll se e whch way works best. But I've always done on trans install
This is a t56 magnum, so it's brand new no core. Level 6 with the clutch flywheel and shipping to NY was $7000
I appreciated the input on the master. However, being all click together plastic, and the fact that I already have everything I need I'm staying with this. The way it's gonna work will be much atronger then oem. Basically using steel plates and 4 bolt holes to hold the pedal to the firewall, then the 2 bolts holding master to all that.
Difficult to explain, but you see. PLUS I'm going to have an adjustable master which will be sweet
Old Jan 24, 2014 | 05:36 PM
  #34
bgray's Avatar
TOTM: June 2007
That's a grey solution you made for the pedal. I'm basically cutting that whole piece off so the pedal bracket sits flush with firewall, eliminating that plastic that a oem master clicks into
Old Jan 27, 2014 | 03:03 PM
  #35
bgray's Avatar
TOTM: June 2007
Had an opportunity to work on my clutch pedal assembly. Its ready to go in, just need some tweaking once it goes into the truck.
Gonna paint inside plate satin black, and having outside plate colormatched
Old Jan 28, 2014 | 02:14 PM
  #36
Ketis's Avatar
Ive pulled my t-56 out of my Silverado like 5 times now. (for various resons)
it is MUCH easier just unbolting the trans from the bellhousing and leaving the bellhousing attached to the motor. No need to remove the starter or anything like that.
Just drop the driveshaft, exhaust, slave, and shifter then you are clear
Old Feb 5, 2014 | 04:50 PM
  #37
bgray's Avatar
TOTM: June 2007
Trans is in. mocked up a cross memeber. The 99 has a much smaller crossmemeber then the newer one from a 5 spd i bought.
Had to buy another clutch pedal. I Cut way t much material off the other. The plates are still gonna work, but Im gonna cut half of the firewall one out. I made the plate at work before i really had a good look at it. O well, mistakes happen.
Old Feb 6, 2014 | 02:35 PM
  #38
SYRacing's Avatar
glad things are coming together for you!
It needs to warm up so I can start working on my junk again
Old Feb 6, 2014 | 07:37 PM
  #39
04redfire's Avatar
Looks good. Gonna be a fun truck when it's all done. Wanna sell the crossmember that didn't fit?
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
ls2 dude
Jul 25, 2015 11:08 PM
dantheman1540
Jul 24, 2015 01:50 AM
Ketis
Jul 23, 2015 12:37 PM
bgray
Jul 23, 2015 10:56 AM
