Massive drive line failure.
Old Apr 17, 2016 | 10:15 AM
The disaster truck's Avatar
Registered User
Default Massive drive line failure.
So this happened.
Sheared leaf spring pins. Destroyed drive shaft. Bent rear end yoke. And cracked transmission. Punctured fuel tank. Rear end has fallen out of of cradle and landed in c notches.
Hint it's not supposed to be laying frame.
Also it's a carbed 350 and th350 transmission. 1994 c1500 4/6 drop.
Anyone care to guess what exactly happened?
Attached Thumbnails Massive drive line failure.-received_1087833801277861.jpeg   Massive drive line failure.-received_1087833791277862.jpeg   Massive drive line failure.-received_1087833781277863.jpeg   Massive drive line failure.-received_1087833721277869.jpeg   Massive drive line failure.-received_1087833691277872.jpeg
Old Apr 17, 2016 | 10:59 AM
blown02408's Avatar
02 w/ lowest mileage 2800
Did you shear all the axle u-bolts when that happened? Looks like you pole vaulted.
Old Apr 17, 2016 | 11:38 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Bad drive line angle or the drive shaft was too long.
Old Apr 17, 2016 | 11:51 AM
Registered User
Ubolts and girdles all still together none sheared. Drive line angle was just set using a digital angle gauges last weekend along with new u joints. Drive shaft seemed a little long. However there was still about a half inch more it could have moved in to the transmission when replacing ujoints. I did buy the truck recently and it had been swapped and had flip kit installed. However drive line angle was out horribly when I purchased it and the axle was only held to the springs using ubolts around the axle tube. I replaced it with a new complete flip kit.
Old Apr 17, 2016 | 11:56 AM
1FastBrick's Avatar
Something bound up or moved, Unless the trans blew first.
Old Apr 17, 2016 | 12:13 PM
Registered User
I was just leaving a stop sign. Under maybe 1/4 of throttle. I noticed that the passenger side leaf spring pin sheared off. I'm not sure if it happened first or when the axle came out of the carrier. And slammed the truck on Springs. If it happened first I can see the rear end dog tracking binding up the drive shaft and letting everything go. The only problem with so much destroyed it's hard to tell what exactly caused the issue. I might find out more when I get the bed ripped off and the transmission pulled. Thinking about swapping rear end out at same time. Which should eliminate everything that could have bound. Tow truck driver hooked me up with a 88 full sized van for 125 since there only getting 100 or less when the drag them across the scales so. So I got some replacement parts.
Old Apr 17, 2016 | 08:04 PM
tgui's Avatar
At least the truck lives up to your user name.
Old Apr 17, 2016 | 09:26 PM
Wolftrk99's Avatar
First thing that comes to mind looking at pics is the ubolts backed off enough to allow movement which sheared the locator pin, something with the u joint bound up finishing it all off, which end of the ds came apart, the trans slip yoke or the rear joint? I shot a driveshaft out of my 86 k5 few years ago because the ds was at wrong angle after lift, on way to the machine shop that was going to measure and build the new one!!!
Old Apr 17, 2016 | 11:06 PM
Registered User
Both ends came apart had to pick it up off the road.
rednekferlife101
Apr 18, 2016 09:37 PM
JASON 77
Apr 17, 2016 01:19 PM
someotherguy
Apr 14, 2016 04:59 PM
Skip Fix
Apr 12, 2016 12:44 PM
LJ93Z28GM
Mar 25, 2016 09:46 PM
