Making 60E hold up to cammed LS1. what do i need?
Old Aug 28, 2009 | 04:52 AM
griff04's Avatar
Default Making 60E hold up to cammed LS1. what do i need?
i have a 07 Classic CCSB. The LS1 has the TSP torquer 2 and is going in soon just wanted to get some advice on what i need for the 60E. I do tow a small boat and a show truck so i have to keep that in mind. any suggestions would be much appreciated. i do not want to do a 80E swap. thanks
Old Aug 28, 2009 | 07:43 AM
Gregg Nader's Avatar
Sonnax Performance Pack kit HP-4L60E-01 --> http://www.sonnax.com/announcements/HP-4L60E-01.pdf
4L70 servo (GM# 24230441 & 24229157). Check with dealer to see if you already have these in your truck. If you do, then go with the “corvette” servo which is the next size larger. These and synthetic fluid should do for starters.
Is it a daily driver or are you planning on racing ? If you are planning on going inside the trans, there are plenty of other things you can do as well.
Gregg Nader
Sonnax Tech
Old Aug 28, 2009 | 12:19 PM
griff04's Avatar
yes it is a daily driver. i do not drive it very hard at all. may get on it a little every now n then just to suprise a few folks.
Old Aug 28, 2009 | 12:20 PM
nightrunner's Avatar
Mr. Obvious
see the sponsor FLT to the right
Old Aug 28, 2009 | 12:49 PM
griff04's Avatar
any torque converters that you would recommend? i was looking at the Circle D 278MM street series 2800 stall
Old Aug 29, 2009 | 04:00 PM
stevenc's Avatar
I personally would go a little bigger on the stall with that cam.
Old Aug 29, 2009 | 04:53 PM
griff04's Avatar
well i was just kinda worried about too big of a stall since i do tow a few things. id say 2 weekends out of a month i am towing either my boat, my show truck, or a trailer load of ATVs.
ARC
57
Feb 21, 2022 10:54 AM
Go5.3tt06
Sep 12, 2015 09:29 AM
steves86ta
Jul 28, 2015 10:21 AM
06 4.8
Jul 14, 2015 08:09 AM
banker099
Jul 4, 2015 05:50 PM
