LQ4/4L80 pullout swap questions
Old May 5, 2014 | 06:04 PM
swolbynos's Avatar
Default LQ4/4L80 pullout swap questions
Hey all, I have a few questions to ask regarding an LQ4/4L80 swap.
I have a 2000 silverado rcsb with a 5.3/4L60. I have found a few 01/02 LQ4/4L80 pullouts for a reasonable price ($2k ish). These are complete with all wiring and ecu. An external trans cooler with the appropriate fittings will getting installed as well. I have already purchased a tubular trans mount for this swap, so that is taken care of.
My questions are:
Will the wiring be pretty much plug and play since the years are similar?
Will the stock driveshaft work with this setup or will I need to order a custom shortened shaft? ( I have seen some conflicting info on this subject)
What other items will be needed assuming everything is is good condition on the pullout?
Any help is much appreciated,
Nathan
Old May 11, 2014 | 10:14 PM
swolbynos's Avatar
Bump, anyone have any information on this?
Old May 12, 2014 | 11:27 AM
slow67's Avatar
Gingervitis Addict
2wd or 4wd?
Old May 13, 2014 | 06:24 PM
Courtntan's Avatar
Wiring is different, need to add a second speed sensor and swap a couple pins. Driveshaft length depends mostly on your truck's ride height I believe.
Old May 15, 2014 | 11:51 PM
swolbynos's Avatar
The swap will be 2wd to 2wd.
I am planning ro use the 2500 trucks harness to prevent the wiring swap.
I am asking if anyone knows whether or not the 1500 and 2500 harness Connect to the chassis the same.
creekrat
Aug 2, 2015 01:27 AM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
bsn1989
Jul 16, 2015 08:20 AM
