Lowering the rear of a 4wd 2500HD
Old Apr 28, 2005 | 11:44 AM
tberkhouse's Avatar
Default Lowering the rear of a 4wd 2500HD
I want to lower the rear of my new 4wd 2500HD so it rides level, and makes towing a 5th wheel easier. I want to maintain stock ride and load capacity, so have decided to simply go with lowering shackles (and pinion shims if needed). From my measurements, the truck sets about 2.5-3" high in the rear. So, I know that BellTech makes a lowering shackle (Model # 6403) that is 4.25" longer hole to hole, so that should lower the rear end about 2 1/8" (just about right). My question has to do with strength. This truck is used for medium weight towing, and hunting and fishing using 4wd. So far, the only brands I have found BellTech and Western Chassis make theirs out of 3/16" steel (the same as stock). It seems as if the longer shackles would be better if they were constructed of thicker steel. Does anyone make a stronger lowering shackle?
Old Apr 28, 2005 | 01:10 PM
They are fine I have had belltechs on my 98' 3500 for five years now and I regularly tow and haul and live down a pretty shitty road. There have been zero problems with them. If I load it really heavy the backend will squat lower than the front and it then handles and rides funny but that is to be expected.
Old May 19, 2005 | 12:10 PM
tberkhouse's Avatar
How long are your Belltechs? They told me they make 2 versions - one is 9.25" long and the other is 11.25" long.
DarkhorSe_SS
Aug 20, 2015 08:58 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
Allgonoshow
Jul 29, 2015 04:21 PM
MileHighSierra
Jul 22, 2015 11:19 PM
