Lowering Question
Old Jul 21, 2011 | 08:19 AM
Default Lowering Question
Getting ready to drop the truck. Plans are to use dropped spindles up front and rear hangers out back. Truck is a 2001 RCSB and already has dropped shackles installed on rear. 2 questions though....
With using the spindles, the geometry stays the same up front but will an alignment be needed after the install?
Will it be necessary to shim the rear or will the pinion angle stay where it is using the dropped hangers? Don't want to run into vibration issues or binding once it's done.
Old Jul 21, 2011 | 10:29 AM
03regcab sierra's Avatar
U will probably have shim the axle I did with my shackle hanger drop. Im not syre u would need an alignment but to be safe it wouldnt hurt to get one anyway
Old Jul 21, 2011 | 04:23 PM
Beatdown Z's Avatar
Laid Back
My alignment was totally out of whack after installing drop spindles. Other brands may not be as bad, but you should still get an alignment to keep everything in spec.
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Nov 5, 2015 06:49 AM
spiritfish
Aug 23, 2015 09:58 PM
USMCvet0311
Aug 1, 2015 07:45 AM
