Lowering a 4wd question
Old Apr 18, 2007 | 09:05 PM
sv650lex's Avatar
Default Lowering a 4wd question
I'm going to be helping a buddy lower his 04 gmc 4wd ecsb and were trying to figure out the best way to do it (control arm, Keys, spindles), and also how low we can go with out major mods.
Old Apr 18, 2007 | 09:11 PM
nightrunner's Avatar
Mr. Obvious
what do you mean by major mods
up front you can do control arms, spindles, torsion bar keys, all of those together will net about 6-7" depending on how much the tbars are cranked
and in the rear you can do what ever you can to the 2wd version + take out the lift block and add 2wd ubolts which is shackles, hangars, !liftblocks, 4" lowering springs, that is 10" altogether right there or go with a flip kit and 2" lifting shackles(turn into lowering shackles when on flip kit) and take out liftblocks for 8"
Mr. Obvious
do a search on GMracer he has a 4x4 with about a 6/8 equivalent drop
Old Apr 18, 2007 | 09:16 PM
blake2kz71's Avatar
also check out kysilverado he has the DJM 3/4 kit.
Old Apr 18, 2007 | 10:01 PM
sv650lex's Avatar
If we go 8" in the rear do we need to c-notch the frame. It's also his daily driver so I don't think he'll want to go more then 4-6 because of the snow in the winter.
Old Apr 19, 2007 | 11:22 AM
4-6 from a 4wd stance is 2/4 from 2wd stance since our trucks sit 2" higher then 2wd... so basically get a 2/4 drop kit, and remove the lift blocks in the rear and slap on stock 2wd ubolts, spindles up front and decrank the keys a lil till your level. if you go anymore in the rear yes you need to notch it, im 6/8 4wd or a 4/6 2wd stance right now.
maxspeed05V
Nov 11, 2015 04:20 PM
USMCvet0311
Aug 1, 2015 07:45 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
Allgonoshow
Jul 29, 2015 04:21 PM
vmaxpro
Jul 27, 2015 10:45 PM
