lowered 4wd with keys need help!!!
Old Sep 27, 2010 | 08:21 AM
mean94lt1's Avatar
12 Second Club
Default lowered 4wd with keys need help!!!
well i just lowered my 00 silverado 4wd with keys in the front and remover the blocks and did shackles in the rear i went to do the alignment and i cant get the caster/camber anywhere near what it needs to be im at -1.7 on both sides right now does wnyone make adjustable control arms or a camber kit for these trucks did some searching but no luck any help would be appreciated thanks
Old Sep 27, 2010 | 08:38 AM
Wyttrash96's Avatar
I hate my cats
DJM makes 3 inch drop lower control arms. Wish I had known that when I had to replace my lcas before it would pass inspection.
Old Sep 27, 2010 | 02:36 PM
anarchyracing101's Avatar
I did drop spindles in conjunction with drop keys on my 99 4wd silvy and was able to get the wheels aligned without a problem or complaint from the shop. My blocks are removed from the rear as well.
Old Sep 27, 2010 | 09:36 PM
mean94lt1's Avatar
12 Second Club
i wish i could say the same im maxed out with my alignment and i cant even get the alignment close im guessing they dont make an upper control arm or anything to help with alignment?
Old Sep 28, 2010 | 09:35 AM
DV2000NJ's Avatar
13 Second Truck Club
DJM does make an upper control arm kit to help with alignment.
Old Sep 28, 2010 | 09:59 AM
mean94lt1's Avatar
12 Second Club
i called and they said they only make an upper control arm for 2wd trucks?
DV2000NJ's Avatar
That's really weird, because I know Black04 is running some DJM UCAs on his 4wd.
BCraven1018
Nov 2, 2015 07:18 AM
Superman09
Sep 25, 2015 05:55 AM
bluestang50
Sep 21, 2015 08:36 AM
Justin87gn
Sep 10, 2015 12:06 PM
