Lost all forward and reverse gears-oil pump???
Old May 19, 2014 | 01:01 PM
Vortec350ss's Avatar
Do yourself a favor and pull the pan before you pull the trans. Sounds like a pump failure... but you never know.
Old May 19, 2014 | 05:30 PM
DoubleDeuce_Hauler's Avatar
Also ready pulled the pan, fluid was clean and there was nothing else in the pan so thats good. I've got everything unbolted and unhooked. Just about to slide the trans out.
The pump is at the front of the trans correct? mates next to the torque converter?
Old May 19, 2014 | 05:38 PM
03sierraslt's Avatar
Yes...
Old May 20, 2014 | 03:38 PM
poundsofjane's Avatar
Check to see if oil level on stick goes down when you start engine. If it doesnt, it's probably the pump stator. Had same thing happen to me when I changed converters. Make sure you have proper spacing between converter ad flex plate. Should be about .250. Give or take about an 8th inch. Anymore than that it not engage pump properly and thus,breaks pump. Good luck man.
ARC
57
Feb 21, 2022 10:54 AM
captrob62
Aug 3, 2015 08:44 PM
MileHighSierra
Jul 22, 2015 11:19 PM
MileHighSierra
Jul 12, 2015 12:23 AM
