LineLock with ABS
Old Jun 27, 2005 | 10:40 PM
Default LineLock with ABS
I'm looking to put a line lock on my truck and was wondering how many of you were doing this. If so then does any one have any installation tips on it? I know I read some where that you have to mount it to stop flow to the rear with ABS. Any ideas?
Old Jun 28, 2005 | 12:32 AM
I'm curious on this too. I know someone did it awhile back and it was actually reversed of what it would normally be. Did you try doing a search?
Old Jun 28, 2005 | 09:52 AM
OBXMarine's Avatar
Yep, something about a line lock, nitrous, and burnouts.
Old Jun 28, 2005 | 09:55 AM
Leroy_454's Avatar
Contact MagicChicken, he did the install on his rig.
Old Jun 28, 2005 | 10:51 AM
Wilde Racing's Avatar
How do I change this text
I also put one on my truck. I did it just like MagicChicken, I hooked it up so it stops flow to the rear wheels.
I mouned a plate to "box" the frame in to mount the lock. really ease.
Old Jun 28, 2005 | 09:48 PM
Thanx guys, Any pics on this set up?
Old Jun 28, 2005 | 09:54 PM
litreddevil's Avatar
Banned
HAVE YOU TRY IT AT THE TRACK WITH SOME D/R TIRES TO SEE IF IT WILL HOLD.
Old Jun 29, 2005 | 09:52 PM
negativeswitches's Avatar
if you install it to lock ou thte rear you have to mount the lock reverse flow of if you would use it in the front at the m/c
Old Jun 29, 2005 | 10:00 PM
i dont understand, so instead of stoppin the "unflow" from the front u hook up the stops to the rear brake lines and press it then hit the brake?
Old Jun 29, 2005 | 10:12 PM
so your basicly mounting the kit backwards. Right?
