Limiting straps?
Old 06-15-2011, 07:47 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
Summit has kits, cheap. DOIT.
Old 06-15-2011, 09:43 AM
AndysC3's Avatar
I copied Chase with the offroading straps. Workes very well so far.
PM me if you need the parts list.
Old 06-15-2011, 11:02 AM
1slowz71's Avatar
Subscribed ! Interested in this my truck does the same ! Andy can you pm the part list thanks ! And bill you would not happen to hae a link from summit would you ? I'm on my phone so can really look thins up at the moment ! Thanks guys !
Old 06-15-2011, 11:10 AM
03sierraslt's Avatar
Wonder how this would hold up to hard launches? You say chase is running the same on his SSS?
Old 06-15-2011, 11:12 AM
Bumpers's Avatar
Anyone with a lifted up truck if you run limiting straps and have them tightend up without decranking does it keep the truck from wanting to walk all over the track or do you still need to decrank it ?
Does it attach to lower shock mount?
Old 06-15-2011, 06:08 PM
1Bear's Avatar
Here the link to Chase's thread: https://www.performancetrucks.net/fo...d.php?t=414845
He made an excellent step-by-step how-to, with great pictures.
Old 06-15-2011, 06:29 PM
AndysC3's Avatar
yep, thats the link that I followed. Works great. I have leveling keys cranked all the way and the strap a tight as it will pretty much go. On hard launches it will only lift about an inch. I have a video from my gopro at the track. I'll see if I can find it and I'll post it up.
Old 06-16-2011, 05:39 PM
2004SSS's Avatar
straps dont break , ask any guys racing real score.
kevlar straps are used on stuff beat on 100x harder than any launch we can muster up .
i made a set a while back , imo these can be easily adjusted , look clean and work great , they also pick up slack when not in use at the track with the clevis bolt and spring
if you need these do it right, i have now swapped to qa1 shocks and can adjust them however i want to make no movement at all with the turn of a ****
here is the info on mine
http://www.silveradoss.com/forums/to...our-front-end/
zblee
11-11-2015 12:41 AM
Gadgetized
117
09-27-2015 10:28 AM
FlowmasterMufflers
09-11-2015 03:32 PM
Quick Reply: Limiting straps?
