Lets talk 6l80!!!!
Old Jan 8, 2017 | 09:12 PM
  #171
UV231 Project's Avatar
Originally Posted by FFDP
I'd do an adapts resets along with cleaning the MAF sensor and get a tune on that thing.
I own HP Tuners have tuned a few of these 6L80e's now, the tune makes all the difference in how they run.
What changes are you making in the tune to make the difference?
And what difference is is making? Details Please
Old Jan 8, 2017 | 09:27 PM
  #172
FFDP's Avatar
Changes to shift times, shift pressures, on-coming pressure presets, shift adapts and things like that. It depends on application and what someone might want for the changes made. Trucks are heavy and handle certain changes less than say a car that is 1500lbs lighter. The changes can make the lag between shifts go away and make up/downshifts crisp and smoother.
I've typed some things up before and said stuff on the hp tuners forums about some changes I've made. It just takes way too long to list a step by step. I'm no pro tuner by any means, this is just a hobby I like to do.
Old Jan 8, 2017 | 09:35 PM
  #173
Thank you.
Old Jan 10, 2017 | 05:34 PM
  #174
Tboostin's Avatar
I talk a lot to the techs at my dealers, and I was told that the 6spd always has two clutch packs engaged and the new 8-10s will have three! So they are a big fan and say they never see the 6 vs the 4s. By the tuner I use and circle d trans builder said, its all in the tune before you over power and break hard parts. I'll be seeing my tuner this weekend about what the stock converter is good for. It's my work truck with Texas speed stock converter cam, DOD, VVT delete. With TS 17/8 header with off-road Y Db corsa exhaust and just added the magnuson 1.9 (3.75 pulley) and just ordered the 3.2 pulley, cnk-pin kit, zr1 map sensor. I guess it should be around 500whp... Should be fun!
Old Jan 10, 2017 | 07:57 PM
  #175
07Softail's Avatar
what year model truck do you have?
RT
Old Feb 26, 2017 | 01:57 AM
  #176
Wolftrk99's Avatar
These are the pliers for the center support snap ring, for anyone that has never seen them!!
Old Feb 27, 2017 | 07:58 PM
  #177
91LT16SpeedFormula's Avatar
I know those all to well too lol
Old Feb 27, 2017 | 08:28 PM
  #178
07Softail's Avatar
Yup... They biguns!
RT
Old Feb 27, 2017 | 09:03 PM
  #179
Wolftrk99's Avatar
I want a pair of those, a pump alignemt tool, and the pliers for the for the 1-2-3-4/3-5-R drum...
Old Apr 4, 2017 | 07:18 AM
  #180
blownescalade62's Avatar
I have a built Circle D trans I lost gears 456. Still have reverse and 123 gears. Any ideas off hand?
