Lets talk 6l80!!!!
Old Aug 28, 2016 | 04:21 PM
  #121
jtphelps289's Avatar
What would be the appropriate fix for a stuck valve? Tune should be getting looked at soon to address anything there that might be out of wack. Thanks again
Old Aug 28, 2016 | 05:32 PM
  #122
Wolftrk99's Avatar
Figureing out which valve it is and either replacing that section of the valve body, or cleaning the bore and possibly replacing the valve, probably with a sonnax valve, if it available.... Really need to figure out when gear its dropping to when it does it and if manually shifting it doesnt do it, that may lead to a dofferent valve, need pull up the operating literature to figure out what applies/releases at what point...
Old Aug 28, 2016 | 06:16 PM
  #123
Sounds like a good time to just go ahead and get the zipkit and the other sonnax parts
Old Aug 28, 2016 | 08:50 PM
  #124
Wolftrk99's Avatar
Yeah but you wanna diag this issue first..... Before you go adding extra go fast goodies to the mix!!!
Old Aug 28, 2016 | 09:34 PM
  #125
07Softail's Avatar
I agree with that one. But you might have to go deeper into it.
RT
Old Aug 28, 2016 | 10:02 PM
  #126
Took it out today and tried getting into it at a bunch of different speeds and throughout different trans temps and never once did it act up like I described, guess I'll have to wait and see if it happens again and remember to pop it into manual to see what gear it's dropped into. Trans fluid doesn't smell burnt or discolored and isnt over or filled or under the correct capacity and was serviced ab when the converter and motor swap was done about 16kmiles ago
Old Aug 28, 2016 | 10:21 PM
  #127
Wolftrk99's Avatar
Taht really sounds like a sticking valve... Had a camaro that had a similar situation, but was when you came to a sudden stop and then went to take off again, it would chirp the tires... Ended uo having an intermittently sticking valve....
Old Aug 30, 2016 | 04:18 PM
  #128
07Softail's Avatar
Might also be the Shrunken check ball that sticks in the separator plate.
RT
Old Aug 30, 2016 | 09:17 PM
  #129
Think a little trans seafoam might clear them up to help from sticking just brainstorming since i really don't have the funds to tear into the tranny
Old Aug 30, 2016 | 09:36 PM
  #130
07Softail's Avatar
Nah... It wont get any better.
RT
