Lets talk 6l80!!!!
#122
Figureing out which valve it is and either replacing that section of the valve body, or cleaning the bore and possibly replacing the valve, probably with a sonnax valve, if it available.... Really need to figure out when gear its dropping to when it does it and if manually shifting it doesnt do it, that may lead to a dofferent valve, need pull up the operating literature to figure out what applies/releases at what point...
#126
Took it out today and tried getting into it at a bunch of different speeds and throughout different trans temps and never once did it act up like I described, guess I'll have to wait and see if it happens again and remember to pop it into manual to see what gear it's dropped into. Trans fluid doesn't smell burnt or discolored and isnt over or filled or under the correct capacity and was serviced ab when the converter and motor swap was done about 16kmiles ago
#127
Taht really sounds like a sticking valve... Had a camaro that had a similar situation, but was when you came to a sudden stop and then went to take off again, it would chirp the tires... Ended uo having an intermittently sticking valve....
I agree with that one. But you might have to go deeper into it.
