jakes stage 3 showed up
Old Mar 16, 2014 | 10:28 AM
  #81
greasemykey's Avatar
can i install the VSS from my 60E or is it a different sensor that i need?
Old Mar 16, 2014 | 10:33 AM
  #82
TIM Z's Avatar
11 sec. Truck Mod
Yeah you don't need to hack it up with a 60 tune anymore , use HPT and do it 80e style with the TCC unlock/ lock controls works great on mine and others .
Old Mar 16, 2014 | 10:39 AM
  #83
that was my plan to segment swap but i was unclear on what sensors need to be hooked up. i have 2 new PCM pins and the connector but i noticed the trans didnt have that sensor. are the ISS and VSS sensors the same
Old Mar 16, 2014 | 10:51 AM
  #84
03sierraslt's Avatar
On a 80e the ISS and Vss sensor is the same. The 60e uses a different sensor.
Old Mar 16, 2014 | 11:05 AM
  #85
damn it. me and bad luck. it could be raining ***** and i would get hit with a dick. ok ill pick one up today
Old Mar 19, 2014 | 06:45 PM
  #86
Bought a precision 447 and it won't fit in the th400 slip yoke wtf?
Old Mar 19, 2014 | 06:58 PM
  #87
And how are you guys mounting the shift cable bracket mine off the 60 won't fit because of the harness plug
Old Mar 19, 2014 | 07:40 PM
  #88
shupe's Avatar
The 80 cable bracket works great.
Old Mar 19, 2014 | 08:09 PM
  #89
Well **** Jake didn't give me one and I thought mine would work. Time to find one of those
Old Mar 19, 2014 | 11:38 PM
  #90
trans is installed, wiring done, just need the correct u joint, dipstick and tube, and the bracket for the shift cable
