installing ss brake lines
Old Aug 7, 2006 | 05:24 PM
stone150's Avatar
Default installing ss brake lines
can someone tell me how to do this? and if i ad speed bleeders to it what do i need to do?
Old Aug 7, 2006 | 06:31 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Attach ss line to hardline get someone to pump the brakes till no more air comes out and tighten down the end that goes on the caliper and ur done.
negativeswitches's Avatar
really simple i did this mod 2 weeks ago
remove old line, replace with new line, bleed that corner, then move on to the next wheel. nothing dramatic about it took me about hour and a half in my gravel driveway to do all 5 lines
i reaccomend you start with the axle flex line and the pass rear corner and bleed that first, then the other rear pass front and drivers front, in that order your supposed to bleed brakes from the longest line first but since your abs pump is mounded under the cab it dosent really make a big diff.
-Erik
Old Aug 8, 2006 | 02:14 AM
Keith's Avatar
Where did you guys get your SS line from?
Old Aug 8, 2006 | 05:28 AM
leochevy2001's Avatar
i know byunspeed has them. you might want to search through some of the sponsors on the right to see if they might carry the ss brake lines.
Old Aug 8, 2006 | 10:01 AM
silver-mod-o's Avatar
Hunt&Fisherator
I think Dub Silverado can get you some... dont quote me on that though... I do believe he can AND he's a new vendor
Old Aug 8, 2006 | 10:46 AM
i got earl's hyperfirm lines from thunder racing, no complaints at all
-Erik
Old Aug 9, 2006 | 12:40 AM
Keith's Avatar
Thunder Racing was the name I was looking for. I had heard of someone else getting the lines from them. I bet Tbyrne has them too.
Thanks.
Old Aug 9, 2006 | 11:58 AM
i ordered from TR and had my lines 2 days later they are very quick
Old Aug 9, 2006 | 01:20 PM
twister4399's Avatar
Is the 2wd kit the same as the 4wd kit TR only carries the 2wd kit.
Steve-O-08
Apr 19, 2018 09:32 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
mhorn0817
Mar 6, 2016 08:00 PM
thewrx
Aug 12, 2015 08:28 PM
76k10chase
Jul 17, 2015 01:48 PM
