Install a 04 4l60e in a 99
Old Dec 28, 2006 | 09:13 AM
Silverdoman's Avatar
Default Install a 04 4l60e in a 99
My tranny is going I think. It's whinning between 35 to 55 and the check light gave tranny failure. There is a guys here who has a 4l60e out of an 04. I know everything will bolt up. Question is will I have to change my flywheel for the converter to bolt up.
Old Dec 28, 2006 | 10:05 AM
04GIBBS's Avatar
Default Trans
I was under the impression that the trucks are the same from 99-06. I know the cross member in the 2000 trucks are different then what I have but everything else is the same. Isn't the trans in your truck now a 4l60E?
Old Dec 28, 2006 | 10:27 AM
ss64impala's Avatar
04 silverado? its a 4l65e not 4l60 but externally the same.just stronger internally.
Old Dec 28, 2006 | 11:51 AM
Yes I have a 4l60e now. The tranny I lookin at is yours 04GIBBS. You have the flywheel also? Just want all my info correct before I swap out. I have read about the spacer but it's for the 4l80e tranny swap correct.
Old Dec 28, 2006 | 11:56 AM
04GIBBS's Avatar
Default Trans
Unfortunatley I just gave the flywheel and trans mount to another member who I purchased the 6 speed from. I have the complete trans and converter. With all connections in tact.
Old Dec 31, 2006 | 12:58 PM
From what I have read here the crank end is longer on a 99 and a new model won't work. It may work if I changed the converter.
Old Dec 31, 2006 | 01:08 PM
Colby 04's Avatar
what? unless it's got a 6.0 in front of the transmission, it's not a 4L65E.
Old Dec 31, 2006 | 03:06 PM
04GIBBS's Avatar
Default trans
As I mentioned I have the complete setup and it should all bolt up to your 5.3 or 4.8.
99 up is the same drivetrain.
zblee
63
Jun 10, 2023 01:25 PM
XL7
May 5, 2022 01:48 PM
Ferocity02
Aug 7, 2015 08:50 PM
SleeperGMC
Jul 29, 2015 10:22 AM
KyleW707
Jul 29, 2015 08:17 AM
