I'm stupid, and in need of advice!!
Guys I have an 02 suburban and today I notice that there is a small oil spot under the drivers front. Looked underneath and the whole drivers side caliper and axle (stubshaft?) and cv boots are covered in something.
Put it up on the lift and it smells like diff fluid. I inspected bth cv boots closely and find no cracks or apparent leaks from them, but dont they have grease in them instead of diff fluid anyway?
This crap is on the inside of the rotor, and all over the a-arms. Is the axle hollow and allows the diff fluid to go from the center diff out to the ends? Is there a seal or something behind the rotor? Any help on what to replace would be great! Thanks, Ron
From the service manual:
"Front Axle Lubricant Leak Diagnosis
Front axle lubricant leaks can occur at the following locations:
While most front axle leaks may be easy to find, determining the cause may not be. A thorough inspection of the area around the leak may assist in determining the cause of the leak.
Oil Seals
Lubricant leaks from a oil seal may be caused by any of the following:
Sealing Surfaces
Front axles components are assembled using specific sealers. A leak at a surface sealed with sealant is usually caused by a poor fit of the components but can also be caused by the use of the wrong sealant. When correcting a sealant leak, inspect each component for distortion and for nicks or gouges that may prohibit the sealant from sealing properly and when re-assembling the component, use the proper sealant.
Differential Carrier Assembly
Lubricant leaks at the differential carrier assembly can occur at the following locations:
- Axle shaft oil seals
- Differential carrier assembly mating surface
- Drain plug
- Fill plug
- Inner axle tube assembly to differential carrier assembly mating surface
- Pinion yoke oil seal
- Vent tube
Oil Seals
- An improperly installed seal
- A distorted seal
- A worn seal
- A worn shaft
- A brittle seal lip
- A hardened seal lip
Sealing Surfaces
- Drain Plug
- Fill Plug
- Vent tube
Dr X, from reading your post it sounds like it could be the axle shaft oil seals. I did buy a Haynes manual and it mentions the seals briefly, but goes on to say that "special tools" are needed and they recommend taking it to a dealer. Anyone replaced these before and can give me a heads up on what I'm in for? Thanks, Ron
i had my driverside axle seal go out, fairly easy to replace, now my passenger side has gone out (leaking) if you read you owners manual, at some point, ever service interval you are suposed to inspect them, so obviously they suck
The shock was my second guess, first was the power steering leaking......but it smells like diff fluid which is pretty distinctive. This only started after we got a little snow here and I used the 4wd auto. Doesnt appear to be actively leaking since I have been back in 2 hi for the past few days. Stone150, did you need anything special to replace the oil seals? I have replaced one in the rear end, but I'm lost on the front end. Thanks, Ron
I've changed the seal in the passenger side once. It was no big deal. The drivers side looks like you would have to split the case to get the axle out. A bigger deal but shouldn't be to bad.
Anyone know where I can get an entire rebuilt assembly that I can just bolt in and replace what I have now? The truck has 90k on it, If I can get them reasonable, I would just replace both sides and be done with it. Ron
