i need help 2nd broken t-case adaptor
Old Oct 8, 2010 | 05:11 PM
Lowered 93Z's Avatar
Default i need help 2nd broken t-case adaptor
ok guys wtf is going on here do any of you 4wd guys keep cracking the transfer case adaptors?? i am on my second one this year. and NO i dont 4wd launch i dont beat it in the mud u joints are good ( actualy i have never put this one in the mud wow just impressed my self haha) Is there a heavy duty one i can get? any ideas i am so lost i have never heard of this before??
Old Oct 8, 2010 | 07:16 PM
Beatdown Z's Avatar
Laid Back
Maybe change your engine AND trans mounts???
Old Oct 8, 2010 | 08:22 PM
budhayes3's Avatar
PT's Slowest Truck
Well that's a new one to me, where are they breaking, got any pics?
Old Oct 8, 2010 | 08:28 PM
mhotrodscooter's Avatar
Is the truck factory height?
Old Oct 8, 2010 | 08:56 PM
Atomic's Avatar
I have a gauge for that
Ive broken one, but it was from my rear ujoint failing during a WOT pull at around 80-90.
Old Oct 8, 2010 | 10:26 PM
JoeyGC5's Avatar
I've broken one, or found it broke when I bough tmy truck. Supposibly the 99-2000 adaptors are steel, but I never investigated it any further. Also make sure the u-joints adnd mounts are in good shape, plus see if you have a set of wheels way out on balance.
Old Oct 8, 2010 | 11:12 PM
2004SSS's Avatar
seems like something is applying all the stress to that point . like mentioned check bushing/mounts and make sure everything is square.
Old Oct 8, 2010 | 11:58 PM
budhayes3's Avatar
PT's Slowest Truck
I'm trying to think back to the end of May when I swapped my trans (seems like a millennium ago lol)...my t-case adapter was aluminum or magnesium or whatever, but not steel...from what I remember (a lot has happened the past few months so my mind has been a little over worked lol)
Old Oct 9, 2010 | 12:33 AM
the trans mount is good and the otor mounts look good i will check them out better tomorow. the adaptor is crackinng where it bolts to the t case. i dint get it??? its stock height wheeks are bead balanced so they are always good. and i just checked my u joints they are like new???
Old Oct 9, 2010 | 12:58 AM
budhayes3's Avatar
PT's Slowest Truck
Is the trans stock/original? Any abnormal noises, like a bad bearing noise or anything? Autotrak or manual T-case? I wonder if something binding in the T-case could stress the adapter?
