I have the wrong gears in my Yukon!?!?!?
Old Jan 9, 2006 | 12:47 PM
Default I have the wrong gears in my Yukon!?!?!?
According to my window sticker and glove box sticker I have 3.42's. But unless there gearing tranny's different I think I have 3.73's or 4.10's. My buddy has a tahoe with 3.73's and he turns 1900-2000rpms at 70mph. My Yukon turns 2100rpms at 70mph. At 75 its about 2300rpms. Can this be right?
If I do have lower gears I'm going to be pissed!!!!!!!!!!!
Old Jan 9, 2006 | 12:48 PM
My Silvy with 4.10's and shorter tires runs 2500rpms at 75mph, so I know its close.
Old Jan 9, 2006 | 01:12 PM
CoonToot's Avatar
Are the tire diameters on both vehicles identical? If not, you aren't comparing apples to, well, apples.
Old Jan 9, 2006 | 01:26 PM
Bo185's Avatar
Read the RPO codes in the glove box. Should be one of these!
2006 RPO - GMC Yukon/XL
G80 Differential, locking, heavy-duty, rear
GT4 Rear axle, 3.73 ratio
GT5 Rear axle, 4.10 ratio
GU5 Rear axle, 3.23 ratio
GU6 Rear axle, 3.42 ratio
It more than likly the tire size differance giving a differant rpm indication between the two.
Old Jan 9, 2006 | 01:41 PM
I have 265/70/16's with GU6(3.42). He has 245/70/16's with GT4(3.73). My tires are taller and my gears are higher. I should read much lower rpms than him at 70mph, not 200rpms higher. Thats just not right. I need to look and see what gears they come with. It has the heavy duty tow package, but you can get that with 3.42's right?
Old Jan 9, 2006 | 01:51 PM
SSlow 4.8's Avatar
i think it may be 4.10s.. i have 255/75/16's and 4.10's and i run roughly 2300 rpms at 75mph.. lol uh oh...
Old Jan 9, 2006 | 01:54 PM
Is that on the lower side of 2300 or the higher side of 2300? The only available gears for my model is 3.42 and 4.10. I may have to find out for sure, but how?
Old Jan 9, 2006 | 02:08 PM
Fogle07's Avatar
i believe my truck was at a little over 2000 with 3.73s and 255/35/20
Old Jan 9, 2006 | 02:18 PM
shadowamker's Avatar
I have just to the opposite problem. My truck has the towing package and I thought it had 3.73 gears. But it actually has the 3.42s. So, I m pissed over that now.
Hey, think we can convince GM they screwed up our trucks and they need to swap the gears out under warranty? I think they got my order and yours mixed up and now they need to fix it.
Old Jan 9, 2006 | 02:36 PM
ranwalk's Avatar
Pm me your vin# and i'll run it and check the vehicle build through gm to see if it matches your rpo sticker. Also, I wonder if you do have the correct gear, is your
converter locking up in 4th? Have you compared the 2 trucks in another gear other than 4th?
