Hydroboost Conversion Install
Old Jul 4, 2009 | 10:03 AM
  #181
bonj87's Avatar
I would really like to do this to my truck
problem i have is i cant find the hydroboost setup
Old Jul 4, 2009 | 12:08 PM
  #182
2001CamaroGuy's Avatar
http://cgi.ebay.com/ebaymotors/Hydro...Q5fAccessories
just one of the many on ebay.....
Old Jul 31, 2009 | 10:59 PM
  #183
PF-981823's Avatar
(I'm new to forum)
noticed some members had documented problems with driveability (example Atomic - pwr str fade)
I see 03-05 Silverado and Yukon XL have several recalls hydroboost issues
I am converting an '01 Silverado 1500 4WD and planned on using salvage parts. My vehicle is a factory vacuum setup and has 4whl disk. Anyone have problems converting the 01 1500 4WD or have any suggestions?
Would the hydro booster from 99-02 model be a better swap? or allow use of vac pedal?
http://cgi.ebay.com/ebaymotors/NEW-O...QQcmdZViewItem
Old Jul 31, 2009 | 11:25 PM
  #184
Atomic's Avatar
I have a gauge for that
Originally Posted by PF-981823
(I'm new to forum)
I dont have any issues...
Old Aug 12, 2009 | 08:12 PM
  #185
SilveradoXD's Avatar
I had a problem with the HB unit applying pressure to the M/C. I hope that what I found will help someone else. Found the problem. I had originally attached the return line from the HB unit between the gear box and the cooler, this was the problem. There was a significant amount of pressure after the gear box and this was pressurizing the return line - causing the HB unit to apply pressure on the M/C. Once I connected the return line AFTER the cooler, everything worked fine.
So I would recommend to anyone doing this conversion that you either get the correct P/S pump with the 3rd connection OR you connect your return line AFTER the cooler.
Also, I have a perfectly good USED HB unit if anyone needs one, lol. (I bought another one because I thought the HB had a internal seal failure)
Old Aug 12, 2009 | 08:30 PM
  #186
Atomic's Avatar
I attached mine before the cooler without issues....maybe your cooler is partially blocked?
Old Aug 12, 2009 | 08:36 PM
  #187
Wow....I feel like an idiot. I went an dug up the diagram they sent me and guess what, rack gets the straight through. I had it backwards (my system is direct into the reservoir).
My bad guys.....
Old Aug 12, 2009 | 08:46 PM
  #188
Atomic's Avatar
The flow through that return line from the booster is very small. A drip normally, and a few tablespoons when you let off the pedal.
Old Aug 12, 2009 | 09:19 PM
  #189
viciousknid's Avatar
Where's the Beef?
What size is the cap on the intake? 3/8 I presume?
Old Aug 12, 2009 | 09:35 PM
  #190
truckmann's Avatar
Did you get yourself a HB setup Josh?
I got the new pedal and lines for mine today and will probably order the HB unit and new pump as soon as I payoff what I owe for my TBSS intake. I found a new take off HB unit and pump at a place in OKC for $140 shipped.
