Hydroboost Conversion Install
Old Dec 13, 2008 | 10:27 AM
  #101
Coban's Avatar
I figured it out!!
The hydroboost I have is off a 2500 Van. They have the square bolt pattern and the longer rod.
I bought the setup off of a tahoe this morning.
Thanks for your input Ky.
Old Dec 15, 2008 | 05:17 PM
  #102
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Can someone please confirm that I got the right parts thanks. The master pump came out of a 04 HD and the power steering pump came out of a 03 hd.
Old Dec 15, 2008 | 05:27 PM
  #103
KySilverado's Avatar
Looks good to me. You'll have to move the one odd bolt in the bracket, or drill a different hole in the firewall.... Maybe switch the mounting bracket with your old booster?
Old Dec 15, 2008 | 05:43 PM
  #104
Low_LSX's Avatar
I'll give that a try thanks for the help. I'll keep you updated about switching the mounting bracket.
Old Dec 16, 2008 | 08:09 AM
  #105
OnyxSilveradoSS's Avatar
so the pump just has twin return ports??
how hard is it to swap the pump...(I know not too bad)
Old Dec 16, 2008 | 10:52 AM
  #106
Coban's Avatar
If you get the bracket with the pump its not bad at all. Just install your alternator onto the new bracket. Otherwise, I think you have to remove the pulley to get to the bolts that mate the bracket to the ps pump. PITA. I could be wrong though.
The bracket is only held onto the block with 5 bolts that are not too difficult to get to.
Old Dec 16, 2008 | 11:59 AM
  #107
howard quick's Avatar
Yep!!
Old Dec 17, 2008 | 08:16 PM
  #108
For the record, I had the same interference with pressure hose touching the rubber boot on the R&P. I carefully bent it out of the way just enough so it won't touch.
Old Jan 10, 2009 | 07:03 PM
  #109
Low_LSX's Avatar
Just got done with mine today thanks to 00Silv4.8 for all the help. All I can say is that it was worth every penny
Old Jan 10, 2009 | 07:04 PM
  #110
Low_LSX's Avatar
I drilled the firewall instead it was easier.
