How are you lowering your AWD?
Old 07-17-2008, 08:08 PM
ObliviouS's Avatar
Default How are you lowering your AWD?
I'm running 20 x 8.5 ADR Imperials with 275/45/20 Hankook Ventus ST RH06 Rubber. I've already got DJM 2 Inch Shackles in the back but i'm wanting to lower it another 2 inches..... front and back. What are you guys using. 2 inch torsion keys in the front and 2 inch hangers in the back? Is this a good idea? Also would lowering it in the front affect my awd? Let me know the pros and cons.
Old 07-17-2008, 08:18 PM
2004SSS's Avatar
spindle front drop and hangers rear or return to stock shackles and get drop leafs. beltech makes both.
Old 07-17-2008, 08:23 PM
ObliviouS's Avatar
which would give me the best ride for the rear? drop leafs or hangers ontop of my shackles?
Old 07-17-2008, 08:32 PM
2004SSS's Avatar
either will be about the same youll need shims if you do the hangers which is easy but i think the leafs come with them , only downside to leafs is towing capacity is lost.
Old 07-17-2008, 08:58 PM
ObliviouS's Avatar
shims for what? correct the pinion angle?
Old 07-18-2008, 11:12 AM
ObliviouS's Avatar
so i need spindles, hangers and a shim kit.... will i have any camber issues? whats a good set of shocks. not too soft but don't want something really stiff..... Edlebrock IAS?
Old 07-18-2008, 11:28 AM
InchUp's Avatar
Correct on the pinion angle.
And the IAS shocks will do well. Look into Bilstein as well.
Old 07-18-2008, 11:49 AM
ObliviouS's Avatar
i had bilsteins on a s-10 before. good shocks. do you guys hit the bumpstops in the back lowering 4 inches. any bottoming out issues?
Old 07-18-2008, 10:42 PM
InchUp's Avatar
I had a customer come in a few days ago with his lowered Denali and he had shorter bump stops in the back. They were red, so I assume they were from Energy Suspension or Prothane. Look to see if one of those sites has a bump stop that will replace yours so you're not riding on it all the time.
Old 07-19-2008, 02:03 AM
ObliviouS's Avatar
alright. thanks.
BCraven1018
11-02-2015 07:18 AM
vmaxpro
09-28-2015 11:10 AM
97_ek
09-23-2015 09:16 PM
trxmxzx
09-23-2015 09:15 PM
Goat's ss
09-22-2015 01:07 PM
Quick Reply: How are you lowering your AWD?
