How much should a junk yard 4L80 cost to use as a "core"?
Old Jun 11, 2012 | 08:02 PM
JeRM82's Avatar
Default How much should a junk yard 4L80 cost to use as a "core"?
I know it's kind or a retarded question, but I am trying to put together the stuff for my 4L80 2WD swap in my 07 classic, and I am looking at some of the companie's core charges for a semi built 4L80. I have seen them from $700 and up for the 80's. I have seen a LOT of guys just get a low mile junk yard 80 for about a grand and instal the shift kit with good luck. My only problem is that I am stationed in California so everyone feels like things should cost an arm and a leg. I work with some good ole boys from texas that talk about 4x4 stuff they go through from junk yards for DIRT cheap.....buuuuttt that is outside of California. SO, what do you guys think.......how much SHOULD a core from a junk yard cost you to buy and turn in when going to a built 4L80? I keep on thinking about selling my 4L70 and that would cover the core cost......not sure if that is a reality for just a stock trans that works without issue......what do you guys think? Any ideas are welcome......unless it is cut a hole in the floor and fred flinstone it to the stripe....I don't own leathers or some fire shoes......ha ha!
Old Jun 11, 2012 | 08:56 PM
mitchellmade's Avatar
MASS seller approved
I buy mine from anywhere 350 to 400 dollars that's over here on the east coast
Old Jun 11, 2012 | 09:15 PM
BlackGMC's Avatar
Resident Retard
I spent 700-800 on mine. It was in good working order, i probably could have ran it the way it was. I did not want to buy a super cheap one with a ton of miles that require replacing alot of hard parts.
Old Jun 12, 2012 | 12:40 AM
JFOLM's Avatar
I talked with a guy who build trans and he told me he has a connection that sells him guaranteed (No broken parts) cores for 300-350. Maybe you can ask a local shop if they will let you know who they use?
Old Jun 12, 2012 | 01:23 PM
Bryant01's Avatar
Whats the year ranges you should stick with? I know the older ones are no good, I found one out of a 2000 obs 1ton dually for $300 locally but not sure if it will work.
Old Jun 12, 2012 | 02:27 PM
pasadenaman's Avatar
I know LKQ was sales on holidays like the 4th of JUly for 50% off, I would check if you have not found one by them or bought one from a sponsor.
Blwn99x
Mar 24, 2023 11:14 AM
SloSVO
Nov 22, 2020 07:34 PM
dsbodley
Nov 14, 2015 09:46 PM
Mark_k
Oct 1, 2015 11:17 PM
murderedSS
Sep 27, 2015 10:16 PM
