How to Identify what year 4l80E???
Old Jan 15, 2011 | 11:51 PM
AMXTREME's Avatar
Registered User
Default How to Identify what year 4l80E???
I am going to buy a used 4l80E and need to figure out what year it is from. My truck is a 98 and I know 93-00 will work. Can I tell by the pins on the plug. I know the cooler lines are together on the 97-00 ones. I basically need to make sure it is not older than 93. Thanks
Old Jan 16, 2011 | 02:37 AM
Atomic's Avatar
I have a gauge for that
Easy way to tell is the post 93 have the rear cooler line fitting near the back. The ones before 93 are right beside each other like the 60e
Old Jan 16, 2011 | 10:45 AM
Wilde Racing's Avatar
How do I change this text
Close, but actually the 4l80e ran the split style cooler lines up to the 97 ish range. They are referred to no center lube transmissions. The 93 and up will work but the only way to make sure it is new enough is to verify the trans housing has the bosses for the neutral safety switch bracket. There are changes that were made in the trans almost every year or so, so obviously the newer the better.
Old Jan 16, 2011 | 05:33 PM
Gadgetized's Avatar
I have heard that the 99/00 ones have the extra bolt hole on the top position for the bellhousing. Mine is out of a 00, and it has it. Supposedly they are the best ones.
Old Jan 16, 2011 | 05:42 PM
Correct, aside from the extra bolt hole at the top of the trans, the trans also has the oil in/out fitting closer together and are known as the center lube style. There are other changes as well involving the reaction carrier and later, the overdrive sprag change. most of the updates can be retrofitted to earlier transmission when rebuilding...
Old Jan 16, 2011 | 10:25 PM
AMXTREME's Avatar
Registered User
WHats this one?
https://www.performancetrucks.net/fo...d.php?t=475784
I need to make sure its not a diesel because then I guess the valve body and torque converter are different.
Old Jan 17, 2011 | 05:02 AM
I havn't heard of valve body changes for the diesels...
Old Jan 17, 2011 | 08:42 AM
AMXTREME's Avatar
Registered User
Just torque converters then. Ill have to get the part numbers off the converter and check. I can always slide the one off my truck and put it on the new tranny.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Oobray
Jun 13, 2022 03:38 AM
XL7
May 5, 2022 01:48 PM
GXPJAY
Feb 13, 2022 08:15 AM
Zacholcomb
Sep 3, 2015 06:14 PM
