How do I change front diff bearing?
Old Apr 8, 2008 | 03:35 PM
stock48's Avatar
9 Second Truck Club
Default How do I change front diff bearing?
The bearing in my front diff is going out. I have replaced the seal twice now and withen two weeks it's leaking again. It is the drivers side stub shaft bearing. I wanted to change it when I had the diff out, but I was told they never go out. Can the bearing be changed without splitting the case, or is it a major job? Does the bearing come out twards the seal, or from the inside? Any info will be appreciated. Thanks, J
Old Apr 8, 2008 | 05:11 PM
KySilverado's Avatar
Looking at the exploded view. There is a bearing on the outside of the case and comes out that way. Looks like you would have to split the case to get the axle out though.
Edit: Just realized you would have had to get the axle out to change the seal. The bearing should be behind it.
5.3Okasai
Mar 9, 2022 01:07 PM
ARC
57
Feb 21, 2022 10:54 AM
5.3Caprice
Nov 7, 2015 08:56 PM
Jake75
Aug 5, 2015 01:26 PM
