high stall vs 4x4ing?
Old Aug 1, 2009 | 10:24 PM
borntobewild99's Avatar
Default high stall vs 4x4ing?
how would a high stall converter affect my truck when offroading. i drive off road quite a bit and will a high stall make it harder to climb hills and uneven terrain?
Old Aug 1, 2009 | 10:30 PM
anybody have any experience?
Old Aug 1, 2009 | 10:32 PM
Atomic's Avatar
I have a gauge for that
Its not as easy, I take mine offroad sometimes, and even with only a 2600 its harder to feel the throttle. If I went offroad often then I would want near stock stall speed.
Old Aug 1, 2009 | 10:35 PM
006rcsb's Avatar
It depends on the manufacturer and how they set up the converter, some are really tight and some are really loose. A tighter converter would be what you want, it would allow for right off idle movement allowing the tires to hold traction, where as a looser converter wouldn't start to grab until later in the rpms and while 4x4ing it might cause more wheel spin. For a tighter converter look at yank's truck thruster series, the tt2600 and tt3000 are both said to be very tight, but will still flash up to their rated stall rpm when going full throttle. For your use I would probably go with the tt2600, i imagine it would mind its manners pretty well on the trails, and from the stoplight when mashed it would still let the rpms jump up for the nice takeoff.
trever1t's Avatar
2nd fastest 5.3 ECSB
for off-road use you want the lowest possible stall speed and gearing to give you crawling power, unless you are into mudding
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Texas5.3_1251
Mar 5, 2016 08:10 PM
06 4.8
Sep 11, 2015 10:36 AM
custm2500
Sep 8, 2015 05:53 PM
11MPG
Sep 8, 2015 04:52 AM
