High Power Drive Train
Old Jun 9, 2006 | 06:42 PM
Lord Aries's Avatar
Default High Power Drive Train
OK, so since i am going nutz and building up a 402 that will probably make 650+RWHP I figure i needed to ask some questions about the drive train... Here is what i have, anything that will need to be changed out to take the power?
- Stage-4 4L80E (No problem here, rated for 850+ at the crank)
- Stage-4 1,600rpm stall TC (No problem here, rated for 1,000HP)
- Stock 1500 truck Transfercase (Issue?)
- Stock Shortend Driveshaft (Issue?)
- 4.56 gears (should be fine)
- Eaton Posi (I really hope this will hold up since i just got it one month ago)
- Oh and 33x13.50R18 All Terrain Tires (Traction will not be a problem )
Thanks
Old Jun 9, 2006 | 07:04 PM
seeyaa's Avatar
1.80e with hd2 kit,4quart pan and big trans cooler
2.you will want more stall then that even with those gears"it will help with any lag"
3.i think parish8 stock T-case was good for 800 rwhp.
4.Give chuck at finish line transmissions. he helped setup parish8 z71 that has over 1000rhp and1000ftlbs. ps he is a great guy very helpful.
black03rcsb
Sep 1, 2015 10:17 AM
slowlsx
Aug 13, 2015 08:28 PM
slowlsx
Aug 10, 2015 05:33 PM
BIGD4504
Jul 28, 2015 11:46 AM
slowlsx
Jul 13, 2015 04:18 AM
