Hesitation in driveline when taking off
Old Jul 18, 2011 | 02:03 PM
GmJackson53's Avatar
Default Hesitation in driveline when taking off
Ok, this has happened twice so far...
05 gmc sierra z71
When i took off from a stop light, i released the brake and gave it gas... The engine reved up but the truck didnt move... Then it caught very harsh and took off... By harsh i mean instant clunk
I checked the tranny fluid, i was almost a quart low... So i filled it, and this hasnt happened again so far...
Any thoughts? Drive shaft seems tight, ujoints look good..
Old Jul 19, 2011 | 06:28 PM
Vince B's Avatar
Being low on fluid could be an issue for sure. I do not think that your issue is with the drive shaft or a differential. It sounds trans related. Other issues could be a cracked accumulator piston, worn bushing in the stator tube causing a leak, plugged filter causing low pressure, or a failing input sprag. Keep an eye on it and see what happens now that you added some fluid to it. Vince
Old Jul 19, 2011 | 10:36 PM
Thanks vince... It hasnt repeated since i added the fluid, im thinking that was the issue, but i was just looking for other opinions, thank you for the input, im doing a fluid and filter change soon... so ill pop the pan and have a good look
Old Jul 20, 2011 | 06:08 PM
Vince B's Avatar
Anytime Jackson. Please update the thread to let us know what you see. Thanks Vince
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
kalikid06
20
Oct 13, 2015 07:37 AM
shootermwc
Oct 8, 2015 01:45 PM
iregret
Sep 7, 2015 01:20 PM
