Hesitation in driveline when taking off
Ok, this has happened twice so far...
05 gmc sierra z71
When i took off from a stop light, i released the brake and gave it gas... The engine reved up but the truck didnt move... Then it caught very harsh and took off... By harsh i mean instant clunk
I checked the tranny fluid, i was almost a quart low... So i filled it, and this hasnt happened again so far...
Any thoughts? Drive shaft seems tight, ujoints look good..
05 gmc sierra z71
Being low on fluid could be an issue for sure. I do not think that your issue is with the drive shaft or a differential. It sounds trans related. Other issues could be a cracked accumulator piston, worn bushing in the stator tube causing a leak, plugged filter causing low pressure, or a failing input sprag. Keep an eye on it and see what happens now that you added some fluid to it. Vince
Thanks vince... It hasnt repeated since i added the fluid, im thinking that was the issue, but i was just looking for other opinions, thank you for the input, im doing a fluid and filter change soon... so ill pop the pan and have a good look
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
shootermwc
Oct 8, 2015 01:45 PM
iregret
Sep 7, 2015 01:20 PM
