Help with Tranny Electrical Problem?
Old Jul 1, 2008 | 02:54 PM
Pharcyde50's Avatar
11 Second Club
Default Help with Tranny Electrical Problem?
Hey everyone,
I need help with a 2003 GMC Sierra 2500hd with a 6.0l & 4l80e. I just bought the truck recently and the speedo seems to hang around 40mph and I'm getting weird shift points in the tranny along with auto volume control on the bose radio goes crazy with the volume. Does anyone have an ideas? So far no codes and I changed the vss out. I'm getting around 10mpg is that normal for this truck?
Thanks,
Scott
Old Jul 1, 2008 | 09:31 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
check the VSSs. Something's definitely screwy.
Old Jul 2, 2008 | 12:23 PM
built408's Avatar
Is it 4wd? If so there is a connector for the vss right above the trans, between the t-case and trans. The wires always pull out of the connector, but you have to pull the conduit off to see it. Wires are purple and green I think. Ive seen it a handfull of times.
Old Jul 2, 2008 | 02:07 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
With the radio and the VSS issue you may want to check all grounds battery to engine and battery to chasis would be first place to look .
Old Jul 6, 2008 | 09:09 AM
Pharcyde50's Avatar
11 Second Club
Thanks for the replies It's 2wd. I changed the vss out already. I'll go through and check all the grounds.
denalircsb
Dec 21, 2020 09:04 AM
kalikid06
20
Oct 13, 2015 07:37 AM
BCraven1018
Sep 18, 2015 08:57 PM
mayko
Sep 7, 2015 12:24 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
