Help new 4l80e is in now truck wont start
#61
lets see, iirc run/crank starter, a/c compressor, fuel pump. I did put them the way they were sopposed to go but still no start. I talked to a gm electrical tech and he said the relays would wotk any way if they are the 4 prong type which in my case they were so...
#62
Was that a tech at the dealership...? He is incorrect, relays need to be installed a certain way or they won't work. If they were installed backwards with power applied, it would put a load on the coil and probably burn it up. The coils aren't meant to take a lot of current. I would double check everything in your underhood fuse box. Verify the relays are working, too.
#64
#65
yeah he works at a dealership. He is a freind of a friend. Apparently he has been doing this for 20 years. IDK. I put them in the direction they are sopposed to go but still no start. I tested all the gry relays. I didn't test the black relays.
I wish i knew a tech that works at chevy who could get my truck in without any problems as it's still under warranty and I am a broke ***. PM me if you know any techs who can do the warranty work. If not I'm gonna have to save up and sell more **** which is gay cause this is my only transportation other than my bike and the gf.
#67
And finally the mother ****** runs. It was the bcm. I went through hell trying to find someone with the software to get it running.
The 80e shifts pretty damn nice. It is way better than the last one. I guess I did a good job. Now That I know it works. time to resave up for a Circle D-- effin taxes.
I am prolly gonna through the wideband in tomorrow.
well **** i'm pooped. I'll throw more input up tomorrow.
#68
Truck is finally running. The transmission shifts pretty damn nice. Way better than the other trans I had. It chirps 1-2 at about 1/4 throttle. Now I need to look into traction. I did a few test runs and it just kept spinning
cams 98 silverado
Jul 31, 2015 07:36 AM
