Help new 4l80e is in now truck wont start
Old Mar 1, 2012 | 08:00 AM
  #51
lady3bglover's Avatar
Originally Posted by silver-mod-o
put the truck in reverse, obviously with the parking brake on and/or truck in the air you rotate the switch until the reverse lights come on, then snug it up. It may not be the right way to do it I guess but its always worked for me.
if your wiring is not right all together though this may not work.
I thought there's only one way that plug can go in b/c of the pins, and I'm assuming you're talking about the 7-pin and not the 4-pin.
Old Mar 1, 2012 | 03:52 PM
  #52
chris092183's Avatar
Originally Posted by Vince B
Outside of the EPC changing in 04 and the wiring harness change to accommodate this the manifold switch is still the same one its always been. Using the late or early set up is not an issue and I have personally done it in the past without an issue. Now I'm not sure if I read this correctly but did you say you have a bunch of fuses that do not have power? If this is the case I would correct this before doing anything else. Find out where the power supply comes from and figure out why its not completing these circuits.
I'm just not getting why there are 2 options for the mps. In no way am I trying to argue with you whatsoever, I just dont understand. You obviously have way more knowledge on transmissions than I do, I'd just like to know why this is option is available. Maybe it's just the parts distributors that have it isted wrong bcause we all know that that is an option even though I found numerous suppliers with the 2 options available. Yes you did read that correctly. I am not getting power from eith side of the circuit. I'm still trying to figure that power supply out. I do think that the gmt900 chassis is a lot more involved and sensitive in comparison to the gmt800. I am going to check the ground connection to the bcm from the link I posted earlier. I printed a 670 page wiring diagram from the internet and I couldn't find this ground in that manual so I might have overlooked it.
I believe what silver-mod-o is stating is not about the placement of the nss connections. I think he is referring to my wiring all together. Also. I am not using nor have I ever utilized the 2 connection type nss.
As always I appreciate everyone's input in troubleshooting my crapshoot of issues with the truck.
Old Mar 3, 2012 | 06:48 AM
  #53
Vince B's Avatar
Originally Posted by chris092183
I'm just not getting why there are 2 options for the mps. I'd just like to know why this is option is available. Maybe it's just the parts distributors that have it isted wrong bcause we all know that that is an option even though I found numerous suppliers with the 2 options available.
There might be an oe one and then an aftermarket one where ever you are looking up your parts at. If you would like to PM me a link to what your looking at I would be more than happy to look at it. My WIT book only has one listed for 91 and up. Your issue is not here. As I stated earlier you need to get power to all of your fuses first.
Old Mar 4, 2012 | 02:22 AM
  #54
1FastBrick's Avatar
Custm2500's Rude Friend
The TCM and the ECM are good and communicating with each other. I don't know if there is a High Speed GMLAN but I do think there are 2 tan wires at the connector so maybe they are apart of 2500 and 2501? I don't know. I'm thinking maybe any wire shorted out to the body can short out the bcm but then again I don't understand electronics and i'm slightly delirious being it's past 3:00am so
I id stumble across this though:
2007 CHEVROLET SILVERADO RECALL - #08V441000
RECALL FOR ELECTRICAL SYSTEM
GM IS RECALLING 857,735 MY 2006-2008 BUICK LUCERNE; CADILLAC DTS; HUMMER H2; MY 2007-2008 CADILLAC ESCALADE, ESCALADE ESV, ESCALADE EXT; CHEVROLET AVALANCHE, SILVERADO, SUBURBAN, TAHOE; GMC ACADIA, SIERRA, YUKON, YUKON XL, SATURN OUTLOOK; AND MY 2008 BUICK ENCLAVE VEHICLES EQUIPPED WITH A HEATED WIPER WASHER FLUID SYSTEM. A SHORT CIRCUIT ON THE PRINTED CIRCUIT BOARD FOR THE WASHER FLUID HEATER MAY OVERHEAT THE CONTROL-CIRCUIT GROUND WIRE.
as well as this
Body Control Modules and Ground Paths - GM Techlink
By Blog Post on September 28, 2011 6:51 PM | No Comments
The Body Control Module (BCM) may be damaged if the module is supplied with battery power when the ground path is removed on some vehicles. The negative battery cable should be removed first before removing a BCM ground on 2006-2008 Monte Carlo; 2006-2011 Lucerne, DTS; 2006-2012 Impala; 2007-2009 SRX, Equinox, Torrent; 2007-2010 OUTLOOK; 2007-2012 Enclave, Acadia, Silverado, Sierra, Avalanche, Suburban, Tahoe, Yukon, Yukon XL, Escalade; 2008-2010 VUE, H2; 2008-2012 CTS, Express, Savana and Traverse models.
When the BCM is powered up (key in the Accessory or Run position) with the ground ring terminal removed or loose, the BCM will attempt to find a different ground path to the vehicle. This different ground path attempt may cause internal damage to the BCM.
The following systems controlled by the BCM may be inoperative or work intermittently because of an internally damaged BCM caused by a lifted BCM ground:
Interior lighting (will remain on or will not work)
Exterior lighting (will remain on or will not work)
Remote Keyless Entry
Door locks
Power windows and mirrors
Remote vehicle start
Remote trunk release
On 2007-2012 full-size pickups and utilities, the BCM can use two ground inputs. Both of these input pins (pins 1 and 5) are located on the X3 connector. The wires from these pins are tied to the same ground ring terminal in the vehicle. (Fig. 11)
The following is a specific list of vehicles and the components that the BCM ground wire passes through before going to the ground ring terminal.
TIP: Remove the negative battery cable if working one of these components.
Hmmm Sounds familiar... Were have I heard that before... In all seriousness I hope you get this figured out soon. If you need help checking the GMLAN lines let me know.
Once you check all the wires and repair anything that may be damaged then most likely it will be the BCM.
For ever one else who has been reading this and offering help. I can read and comunicate with the ECM and TCM But the BCM will only show me the Module ID and software. I can not comunicate with the
Interior lighting
Exterior lighting
Door locks
Horn.
I can how ever talk to the IP. I can sweep the gauges and turn all the warning lights on and off. The Radio works and the HVAC is all lit up.
I spoke with a Gm Master Tech and he said to make sure the GMLAN comunication wires were not shorted to ground. Once verifying all the wireing is good The most likely cause would be the BCM. It's not common but can happen. Especially liked mentioned above about connecting and disconnecting power from the Negative side. He said he could attempt to wake it up by tring to reprogram it and if that does not work then we would have to look into replaceing the module.
I was able to pull the TCM calibration but not the ECM calibration. I believe it is because of the active comunication fault code. I ordered an E38 Harness adapter for my bench top harness to see if I can pull the tune out of the ECM off the vehical. I am hopeing its just the communication fault code and not tunner locked. I would like to make sure we store and protect that info incase we have to go further then the BCM...
Old Mar 13, 2012 | 09:42 PM
  #55
Interior lighting
Exterior lighting
Door locks
Horn.
Thanks Joseph
If my life depended on it i can't seem to figure this sob out.
prior to me removing the old80e my stabilitrack, traction control, driver door window have not functioning properly, remote start not functioning and the problem with the last 80e surging or lurching into gear. After searching for answers I found that the stabilitrak might contribute to many of the above problems and cause a no crank.
I have a 2007 Chevrolet Avalanche, 5.3 Flex fuel. During a - JustAnswer
WHen I parked the truck to do the transmission change (it has been sitting for around 4 months) I parked it with a close to empty gas tank. I read that a near empty gas tank can give you some trouble codes as well. FML
Old Mar 13, 2012 | 09:48 PM
  #56
I did however find some relays that were put in the opposite direction so I am thinking my little brother did that. I haven't got it back together to see if the truck will start with the relays in the correct way, would that casuse my no start, no crank, loss of gmlan communication symptoms?
Old Mar 21, 2012 | 06:18 PM
  #57
03regcab sierra's Avatar
Im having the exact problem with my truck and just cannot find the problem. park lights stay on as well as interior lights. I had forgot to attach 1 ground stap that goes to the driverside firewall when I tries to crank the truck after a motor swap. it doesnt show wat gear its in and it wont crank. I have tried all the above mentioned things that might solve the problem with no luck. I hooked up to different scanners and it gave me a failed connection error also. Is it maybe the BCM thats crapped out?? My truck has also been sittin for a few months now and I need to use it already!
Old Mar 26, 2012 | 04:25 PM
  #58
03regcab sierra: it seems as our problems may be different. My interior lights (dome lights) do not come on. This is really fun huh? well I hope I could be of help to you but I haven't go tmine running yet. I put a new battey in it as well. I knew it wouldn't fix the problem but my battery just went bad from sitting so long. Just for ****'s and giggles I tried to start it, but of course no crank, no start.
Old Mar 26, 2012 | 06:40 PM
  #59
Have u replaced the bcm? Im gonna try that this week hoping to solve my problem
Old Mar 26, 2012 | 10:10 PM
  #60
smokeshow's Avatar
Mod with training wheels
Which relays?
