Help me lower my 06 V-Max 2WD Crew Cab
Old May 3, 2006 | 07:55 AM
Exclamation Help me lower my 06 V-Max 2WD Crew Cab
I want to lower my 2006 Vortec Max 2WD Crew Cab, 2" in the front and 3" in the rear.
It seems when I ask some local shops they are not sure and say they will get back to me. I'm guessing it's due to being a Crew Cab.
I do know Ground Zero and Beltech make lowering kits. I've also heard a tad about McCully or something like that. Will the stock Silverado SS parts lower it 2 & 3"?
I want it to ride/handle like stock and I don't want any geometry problems.
What would you guys recommend? Is this something I can do with regular tools or do I have to go to a shop? I did my own spring swap on my 2001 Camaro SS.
Thanks in advance guys!
Bill
Old May 3, 2006 | 09:49 AM
three83's Avatar
I have a 2005 Silverado 1500 CrewCab. I will be doing a 2/4 Drop in the near future and will use the McGaughy's kit. It includes a 2 inch drop spindle in the front and a 2 inch drop shackle/2 inch leaf spring drop for the rear. I think the 2005+ trucks have a welded hanger for the rear leaf springs so you can't change the hanger like on previous year models. I was told by others using this kit that you keep factory ride in the front and the rear is a little bit softer than factory. Hope this helps.
silver-mod-o's Avatar
Hunt&Fisherator
I am guessing you could use a 2/3 drop kit used on an SS or VHO
Old May 3, 2006 | 09:52 AM
three83's Avatar
I think the kit for the SS and CrewCab's are different. Check out http://www.mcgaughys.com/
Old May 3, 2006 | 10:14 AM
Hunt&Fisherator
maybe so.... I was just thinking that because of the t-bar front sus...
Old May 3, 2006 | 10:54 AM
zippy's Avatar
You're going to want a kit for an 05' and newer VHO.
Old May 8, 2006 | 06:41 AM
Anyone else? Any part numbers? I'm going to guess not too many people lower Crew Cab models...
Old May 8, 2006 | 09:10 AM
zippy's Avatar
I'd recomend sending a pm to JonmalibuSS. He should be able to take care of you.
Old May 8, 2006 | 09:14 AM
Who is this guy? I only found one post by him...
Old May 8, 2006 | 01:45 PM
zippy's Avatar
He's one of the guys who has worked on this. He mostly posts over at SilveradoSS.com
