Help with camber problem
Old Apr 23, 2017 | 04:43 PM
xteam95's Avatar
Default Help with camber problem
im having an issue with my 2010 silverado nnbs. I lowered the truck 6 inches in the front using belltech 2 inch drop struts, DJM 2 inch drop springs and belltech 2 inch drop spindles. Im having a problem correcting the negative camber on the truck and the upper ball joints look out of whack. I was wondering if the DJM upper control arms would fix the camber problem? or if you guys had any other suggestions to fix the problem.
Old Apr 23, 2017 | 05:05 PM
Tig's Avatar
Tig
Hmm, what about the adjustable cam bushings? I think that's what they're called
Old Apr 23, 2017 | 05:42 PM
xteam95's Avatar
I think those only give 2 degrees. I need more than that
Old Apr 23, 2017 | 06:51 PM
Feed's Avatar
Belltech alignment kit, re-indexed Cam plates, offset bushings and belltech 2511 spindles. I still have room for adjustment in the cam plates at 5" drop.
Old Apr 23, 2017 | 09:29 PM
Tig's Avatar
Tig
There you go xteam
I have the 2511 spindles, struts and alignment bushings. Should I grab the cam plates to for safe measure?
Thanks Feed
Old Apr 23, 2017 | 10:02 PM
Feed's Avatar
I've installed the cam plates twice. Grinding out the slot in the upper control arm mounts for the extra adjustment sucks. I would avoid it if you can.
Old Apr 24, 2017 | 03:22 PM
Tig's Avatar
Tig
Sorry, I'm confused. You have to grind out the slots in the uppers to install new plates?
Is that the "re-indexing" you're talking about?
I was shooting for 4" but if 5" is possible I'm definitely going that route.
Old Apr 24, 2017 | 06:06 PM
Feed's Avatar
The slot limits the adjustment. You need to extend the slot 3/8-1/2" towards the pin as shown in the picture. The re-indexed belltech cam plates then let the UCA bolt slide into the extended slot area. Full instructions are on the belltech website. Grinding out the slot with a die grinder isn't fun.
My truck
Old Apr 24, 2017 | 06:32 PM
Tig's Avatar
Tig
Ooooh gatcha, thanks a bunch especially for the pic. You da man.
I play with metal all day so this should be fun hahaha
Nice truck, looks great.
Thanks again for everything
Old Apr 24, 2017 | 09:28 PM
Feed's Avatar
A 1/4" diameter burr in a right angle die grinder would make quick work of it but they tend to grab and bounce around. You'll have more control over an 1/8" diameter burr but it takes forever. Either way I was covered in fine needle-y metal chips. That's the part I hate. I work with mean too, its the really fine chips that hurt the most and are hardest to dig out.
