Help with camber problem
Old Apr 24, 2017 | 09:47 PM
Tig's Avatar
Tig
Thanks for the heads up, I'll cover up before starting.
Random ? = did you have to grind the pin down?
It says something in the instructions about grinding a plastic pin or something like that. Yours seems to be metal.
Old Apr 25, 2017 | 07:56 AM
Feed's Avatar
The pin needs to be ground down flush with the cam plate. If the pin sticks out past the cam plate, it will interfere with UCA bolt head/nut when the adjustment is maxed out.
Old Apr 25, 2017 | 10:57 AM
ILuvJDM's Avatar
It was a pain in the ***, my die grinder kept bouncing and it wallowed out the hole quite a bit. I wouldn't ever do it again, it sucked
Old Apr 26, 2017 | 03:04 PM
Tig's Avatar
Tig
Ok cool, thanks again for everything.
Sounds like it is a pain.
