Help asap!!!
Old Jul 11, 2013 | 01:18 PM
Atomic's Avatar
I have a gauge for that
If you disconnect the cable can you move the shifter on the dash?
Old Jul 11, 2013 | 02:25 PM
cwalker2006's Avatar
No. Even when disconnected it doesn't want to move. I'm gonna charge my battery and see if that helps. Chevrolet all the way saI'd the solenoid might have got stuck and needs some power to release
Old Jul 11, 2013 | 03:24 PM
chevrolet all the way's Avatar
happens at the shop fairly often. so its worth a try!
Old Jul 11, 2013 | 08:41 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by cwalker2006
I just installed my transmission afyer being down for like 9 months. Get everything together and it feels like the gear selector is stuck. I can't move it. When I removed the nut to take off the cable fir the gear selector it turned (switched) gears wothkit the gear selector moving. Is there some sort of safety or did I mess up the cable?
Is the battery Fully charged, the Key in the On position, and you Pressed on brake pedal when you are attempting to move it???
Make sure the steering wheel is able to turn freely before attempting to release the shift lever.
Old Jul 12, 2013 | 12:44 PM
http://i133.photobucket.com/albums/q...712_112500.jpg
Anyone know the purpose of this?
Old Jul 12, 2013 | 01:49 PM
nickleahy23's Avatar
thats just where it joins together..i had a problem when i put my new cable in..i didnt have that pushed together far enough and i couldnt shift..pushed it together and everything was fine..
fwiw, i had my battery out of the truck for 5 months and all i would have to do is put the key forward and i could shift out of park with no power
Old Jul 12, 2013 | 02:26 PM
That's usually how mine was. How do you take that deal apart? It may be kinked up in there or something.
Old Jul 12, 2013 | 02:30 PM
there are tabs that you can press and pull it apart i believe..how many miles on the truck? my cable siezed up under the carpet below the drivers feet from it wearing through the plastic casing.
Old Jul 12, 2013 | 03:06 PM
80k it was perfectky fine when I o ulled the transmission
Pimpinpete
43
Dec 22, 2017 08:13 AM
GM1697
Sep 28, 2015 08:28 PM
MOBBN
Sep 22, 2015 08:07 PM
