Having trouble getting rear rotors off 2003 Silverado
Old May 30, 2009 | 02:55 PM
maddboost's Avatar
Default Having trouble getting rear rotors off 2003 Silverado
I am trying to replace the pads and rotors on my 2003 silverado. I am having trouble getting the rears off. I can get the rotor to slide back and forth a 1/4 but thats it. The parking brake isn't engaged at all. I am assuming the the parking brake shoes have dug into the inside of the rotor which is keeping it from releasing. Is there a way to retract the parking brake shoes so I can get the rotor off?
Old May 30, 2009 | 03:33 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
spin the rotor as you pull it off it worked for me
Old May 30, 2009 | 05:05 PM
006rcsb's Avatar
on some drum brakes there is a little plug on the backside of the backplate that you can pop out and it will allow access to the self adjuster, if so you can just adjust yourself some slack and they should come off.
Old May 30, 2009 | 06:02 PM
Manbearpig's Avatar
Are the little shitty lug nut clips still on?
Old May 31, 2009 | 09:22 AM
fastnblu's Avatar
Agreed. Once those retainers are clipped, it should work. Mine were real hard to get off. Tap on side, go opposite that 180*, spin rotor. Repeat in a different area. If it's done evenly, & not bashed on too heavily on 1 side/ not enuff on the other, it will just **** it. Hammer blows evenly & w/ same force applied is what I'm sayin.
Or did you already get rotors off?
Old May 31, 2009 | 12:46 PM
Noah Burns's Avatar
take the emergency brake off...
Old May 31, 2009 | 01:51 PM
Atomic's Avatar
I have a gauge for that
Undo the cables for the ebrake about in the middle of the truck, they run down the drivers side. You have to pull it forward and slid up the slot and out of the hole.
...you took the caliper off, right?...
Old May 31, 2009 | 09:38 PM
Noah Burns's Avatar
I meant just release the parking brake... we did this on a friend's 04 once, went to pull the rear rotors and banged on it for about 10 minutes before we realized we were retarded and the ebrake was on.
Old May 31, 2009 | 10:08 PM
skolman91's Avatar
yea usually beatin on it then turn 180 and keep reapting works, unless u can tell theres something obviously catching..
Old May 31, 2009 | 10:23 PM
Atomic's Avatar
mine always slid right off... the only thing to catch is if the ebrake is still under tension (Adjusted too tight), which wont be a problem if its disconnected.
