Got Torque ? Broke The Output Shaft
Transmission is apart : looks like I broke the output shaft in two. SOB ! some other damage and lots of metal in the whole unit. Anyone using a case hardened or billet output shaft when you got the new tranny or rebuilt it? Is it worth the $600 or just use an OEM shaft ? don't want to break it again...
HELP
HELP
Originally Posted by TheLadiesMan
DAMN!!! im not sure about my level 4 FLT after hearing about this. no money to upgrade to a level 5
go with a level 5 FLT, have vince set you up. its well worth the wait.
Not sure if your filmiliar with my truck but I have a 4x4 CC that weighs in at almost 5400 lbs with me in it. I have a built motor with a Radix, a FLT level 5 with the 300m shafts and a 3000rpm converter. My truck runs a 7.90 in the 1/8 as does your truck only a lot heavier. Point is I haven't broke a shaft with my heavy truck. Talk to FLT!!!
I weigh 5400 and cut 1.6's 60 ft with the 65E. FLT LV / Vig is doing just fine. I did the billet output shaft, it was a no brainer. I would suggest doing the same.
lukn4trbl355
Oct 21, 2015 11:19 PM
Wrecker 426
Sep 30, 2015 09:39 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
